Jet Central Smoke system question
My Feedback: (90)
Happy New Year jet heads. I wonder, do any of you have the diagram that shows where stuff plugs in on the JC smoke system? I don't have the paper that tells me how to hook all this stuff up. I could trial and error it but why burn something up when I have the best resource in the world.
RE: Jet Central Smoke system question
Jason, Hope this helps.
The pump has 3 wires on it. One is the battery connection one is going to the receiver and the 3rd is for a solenoid. The solenoid
is an option you don't have to use it. If you don't use it make sure to use a on off valve after the pump.
The tubing going from the pump to the solenoid is plugged in backward from the way they hook up for an engine solenoid.
So out of tank to pump, out of pump to solenoid out of solenoid to tubing to back of engine.
Hope this helps
Hope this helps
