Portable Test Run Table
Has anyone put together a portable table for test running 50cc engines? I’m about to start modifying a Black and Decker Workmate. I can lift about 30 pounds max. Thanks, Dan.
http://www.homedepot.com/h_d1/N-5yc1...specifications
RE: Portable Test Run Table
ORIGINAL: All Day Dan
CR
I think the most portable engine test stand is the one where they slip it into the reciever for a trailer hitch on their car or truck. If your trailer hitch uses a receiver, you can fabricate up something to take advantage of it. Then you can test engines wherever you can park your car or truck.
Many years ago, when I had a pickup truck with the ubiquitous steel rear bumper, I had drilled a couple of holes and mounted a J-Tec engine test mount on it and I used it for years that way, at least until I sold the truck.
I personally don't need the portability. I run engines in my driveway. YMMV if you have picky neighbors. You may not be familiar with the Workmate I referred to. It folds up for transport if that's a factor. Not too sure I want the exhaust residue on my truck in any event.
Happy New Year to everyone!
CR
CR
