NGK CM-6 gap setting?
01-11-2013, 05:42 PM
I have a RCGF 40cc twin.
What is the recommending gap settings for the NGK CM-6?
01-11-2013, 06:13 PM
RE: NGK CM-6 gap setting?
I didn't look it up, but memory is saying .025? You could do some digging around on the NGK site to be sure, but that's a pretty safe bet.
01-12-2013, 02:32 AM
It's around .7mm
01-12-2013, 02:51 AM
The width of an Xacto blade works well (.022).
01-12-2013, 03:40 AM
It depends on the ignition the plug is hooked up to. 0.4 to 0.6mm. Standard, the plug is gapped to 0.5mm
01-12-2013, 05:17 AM
X-acto blade works pretty darn well
01-12-2013, 05:46 AM
Gap each plug for a twin so gap is exactly the same. .025 with-in .0000000000000001
01-12-2013, 09:37 AM
WY
0.5mm=.01969.
01-14-2013, 03:16 PM
NY
#11 X-acto Blade and you will never go wrong.
