CARF Eurosport Evolution Canards
Hi i am nearly finished with my Eurosport build and am about to start on the canards, the thing is can someone send some pictures of the left and right canard from the end of the canard so it shows the airfoil of the canard, just it looks as mine are both the same, so if i install the right hand one the airfoil will be upside down so it will not generate lift but push down instead, or are the canards supposed to be like this. i will post pics later today of mine.
Wichet
Wichet
RE: CARF Eurosport Evolution Canards
I think you will find its just the seam line playing with your eyes and they are fully symetrical.
When you set the model up, set the canards with 2mm negative (down) from where the manual says-It rolls more axial)
Dave
Dave
