Fuel tank sizing question
Old 01-27-2013, 06:30 AM
velottatv
Default Fuel tank sizing question
Trying to determine proper fuel tank size for a DLE35-RA. Had an 800cc tank planned but its too tight in the layout.
Will a 550cc (18.5 oz) work?This is in an RCGuys' AG Wagon. How long at normal flying speed do you think this tank will last?</p>
Old 01-27-2013, 06:43 AM
pe reivers
Default RE: Fuel tank sizing question
That tank should last about 15 minutes at WOT
Old 01-27-2013, 06:55 AM
Pete Bergstrom
That should work just fine. Fuel burn should be 1.2 oz per minute at WOT. <div>
</div><div>Pete</div>
Old 01-27-2013, 07:18 AM
SOLO_48
My Feedback: (8)
16 oz is good enough
Old 01-27-2013, 08:38 AM
hauckf
I've read this "rule of thumb" few time on this forum: "A gas engine with a conventional muffler burns approximately its displacement in cc's each minute at full throttle." That would seem to agree with the other replies. (550/35=15.7 min.)
Old 01-27-2013, 08:58 AM
karolh
What's the approximate difference between WOT and say 3/4 throttle, and would using a linear measure be a reasonable assumption.
Karol
Old 01-27-2013, 10:01 AM
pe reivers
it is load dependent, not throttle position.
True assumption: You will use less.
