HGI Yank Eliminator Help!!!
hi im brand new to this whole r/c gas powered car stuff...well i recently got a used off road HPI Nitro MT .15 car from a friend and instead of a pull starter (it was taken off, i guess due to the fact it was broken) well i have no idea how to use this yank thing...he says put it where the pull starter goes and use a drill but it doesnt fit right through the axles...can anyone provide me some information on how to get it to work...and i mean idiot proof ones so i dont mess up...also what are some good upgrade parts for this car so it goes superfast both on road and off. thanxs for your help
RE: HGI Yank Eliminator Help!!!
When you pull off the pull starter there is a little shaft that sticks outs. The yank eliminator goes into the drill like a drill bit. You then put the yank eliminator onto the shaft.
The HG only can be used for side mounted engines, unless of course a person wants to remove the upper rod everytime on the MT. I have both a RS4 and MT so if you need any further assistance ask away.
Do those things have a 1 way bearing in them or something along those lines? Does it suck to pull them off once the engine is started?
LOL, I wish I knew that it only worked on side mounted motors before I bought mine. I have an HPI RS4 RTR btw.
A little machining and it works now.
