Does anyone have Tekin G12C III esc specification?
RE: Does anyone have Tekin G12C III esc specification?
The Teking g12c was a good race level esc. I believe it offered a low resistance, replaceable wires, and adjustable current limiter. Might be a motor limit of 15t and 12 cells but I could be wrong.
Thanks for replying.
I Just want to know what is the ESC resistance, current, and motor limit. It's been sitting under my bed, so I guess the best way is to test it out.
I have the original owners manual and these are the specs it lists:
ON resistance .0007 ohm max
current rating (min.) 400 amps
braking current (min) 120 amps
input power 4-12 cells
BEC volts/amps 6.0v/5.0A high power
limiter current 20-120 amps and bypass max
I run a 10 turn double with my tekin p-12 and have no problems so I think you should be fine to run a hot mod motor with the G-12c III.[sm=bananahead.gif]
