Help for propellers 8517/5
<span class="hps">Hi</span> <span class="hps">everyone,</span>
<span class="hps">I bought</span> <span class="hps">a pair</span> <span class="hps">propeller propshop 8517/5 SSbut propellers are skewed.</span><span class="hps">
<span class="hps">What kind of</span> <span class="hps">skewed</span> <span class="hps">propellers</span><span>, this</span> <span class="hps">is a problem</span><span>?
http://www.youtube.com/watch?v=GwPqn...ature=youtu.be
<span class="hps">my english is</span> <span class="hps">not good </span><span class="hps">Please</span> <span class="hps">type</span> <span class="hps">clearly</span></span></span>
RE: Help for propellers 8517/5
Hard to tell but the prop looks loose on the balancer is it a snug fit that might account for the wobble ?.Does the hole seem centred in the prop ive seen some that werent and yes thet is a big problem.
Mart
Mart
The hub hole doesn't look like its in the centre to me.
For such an expensive set of props you need to go back to propshop.<br type="_moz" />
<span class="hps alt-edited">Thanks all,
<span class="hps"><span class="hps">Watching t</span>his video</span> <span class="hps">was</span> <span class="hps">the second</span> <span class="hps">coming</span>
<span class="hps">they</span> <span class="hps">agreed</span> <span class="hps">that</span> <span class="hps">their</span> <span class="hps">skewed</span> <span class="hps">propellers</span>
<span class="hps">and</span> <span class="hps">took it back.
<span class="hps">
and posted</span> <span class="hps">new ones,
</span>but they was made skewed
<span class="hps">I got</span> <span class="hps">them in</span> <span class="hps">the shop</span>
<span class="hps">He talking</span> <span class="hps">with them to</span> <span class="hps">send it back.</span>
</span>
</span>taken <span class="hps">back to</span> <span class="hps alt-edited">the first pair video:</span>
<span class="hps">http://www.youtube.com/watch?v=df56W...ature=youtu.be
<span class="hps alt-edited">far as I</span> <span class="hps alt-edited">dissect</span><span>,</span>
<span class="hps">Some of the blades long and short
and the propeller</span> <span class="hps">shaft</span> <span class="hps alt-edited">skewed.
<span class="hps">I want to ask</span> <span class="hps">the question;
</span><span class="hps">-more</span> <span class="hps">speed</span> <span class="hps alt-edited">decreases
-<span class="hps">If there</span> <span class="hps">is</span> <span class="hps">turbulence</span><span>?</span>
<span class="hps">
or whatever else</span> <span class="hps alt-edited">creates</span> <span class="hps">problem?</span></span>
</span></span>
<span class="hps">
</span>
<span class="hps">
</span></span>
You cant run the props if there not balanced propperly or you will damage something,any wobble will first cause poor handling but the worst thing is the damage it will cause to your driveline and hardware and worst case scenario your engine itself,dont use an unbalanced prop.It does seem like they have a problem with these props if theyre all coming like that,back to the drawing board me thinks.
If i were you i wouldnt get my props direct from them as they never come propperly balanced and only butterknife sharp they make good props but they do require a lot of work in my opinion,go to dasboata and get them from him as he will work on them so they are perfectly balanced and his props are the best in my opinion.
Mart
Mart
Is it actually balanced?? The videos dont show it stopping? you can balance a prop that don't look right to te eye. It will most probably cavatate like crazy tho. Your balancing your rotating mass at the end of th day. Lets say Your rotating mass your trying to balance is a 2p coin with the hole drilled offcentre... When its balanced it will be round with the hole the centre......
The point is its doesn't look right at all... If its been balanced then its probably had a large about of material taken from the blades to counter act the way it's been formed.
It's a lot drill the hole in the centre than balance the whole lot!!!!
<br type="_moz" />
<br type="_moz" />
ORIGINAL: martno1fan
Mart
Mart
ORIGINAL: Ron Olson
Something is amiss when you can hear in the video of one blade hitting the balancer.
ORIGINAL: Jackal1983
<br type="_moz" />
<br type="_moz" />
ORIGINAL: modeltekneci
Not propshop,</p>
did not Dasboata!!!</p>
Not propshop,</p>
Mart
He is not one of the best, </p>
<span class="hps"></span></p>
yes,he took the propellers</p>
</p>
he was took from me the costs not responsible
</p>
my english not good, I find someone for tell you</p>
ORIGINAL: Justaddwata
Chris is one of the best in the industry and I consider him a friend and a man with the highest credibility.
Please let me know if I can help.
Hi Matt...do you have an email i can reach you? Trying to get some info/pics of a hull you own.
Damon
