hanger 9 bf 109 build
Old 03-17-2013, 01:24 PM
merric
Default hanger 9 bf 109 build
OVER VIEW
Product Specifications
Wingspan: 64.0 in (163 cm)
Overall Length: 59.0 in (150 cm)
Wing Area: 678.5 sq in (43.8 sq dm)
Flying Weight: 10.25–11.5 lb (4.7–5.2 kg)
Engine Size: 0.61 2-stroke glow; 1.25 4-stroke glow
Motor Size: Power 60
Radio: 5-channel radio system minimum
Servos: (3) standard, (4) mini servos
CG (center of gravity): 3.25–3.50 in (82.5–88.9mm) behind leading edge at wing center
Wing Loading: 34.7–39.0 oz/sq ft (107–119 g/sq dm)
Spinner Size: 118mm diameter
Speed Control : 80A brushless minimum
Recommended Battery: 22.2V 6S 5000mAh 30C Li-Po
Flaps: Yes
Retracts: Optional
Control Throw (Ailerons): Low: 16mm up, 14mm down, 10% expo; High: 20mm up, 17mm down, 10% expo
Control Throw (Elevator): Low: 15mm up/down, 10% expo; High: 20mm up/down, 10% expo
Control Throw (Rudder): Low: 25mm right/left, 15% expo; High: 30mm right/left, 15% expo
Control Throw (Flaps): Mid: 35mm; Full: 58mm
Scale: 1:6
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: 20+Hours
Old 03-17-2013, 01:31 PM
merric
Default RE: hanger 9 bf 109 build
FIRST IMPRESSIONS
i opened the box to find every thing in good order, the covering was tight no wrinkles, nothing was broken. The color scheme looks better in person.
i have the e-flite eletracts, and struts to install in the wing. will post pics soon.
Old 03-17-2013, 04:08 PM
hrrcflyer
Hey Merric,
Ibelieve the model you have is the Hanhar 9 Me109. There is already a thread started on the plane, here in the warbird forum.
David
Old 03-17-2013, 05:17 PM
skillet92
http://www.rcuniverse.com/forum/m_11364918/tm.htm
Old 03-17-2013, 08:37 PM
merric
Its a hanger 9 Messerschmitt Bf 109F-2 60
Old 03-18-2013, 05:57 AM
Asanders
Asanders's Avatar
nothing wrong with another build thread.. go for it. Pictures hopefully. thanks!
Old 03-18-2013, 08:59 AM
merric
Here are some pics,
ID:	1863440   Click image for larger version
ID:	1863441   Click image for larger version
ID:	1863442   Click image for larger version
Old 03-18-2013, 09:01 AM
merric
This is the landing gear and pilot i am using.
ID:	1863444   Click image for larger version
ID:	1863445   Click image for larger version
Old 03-18-2013, 09:07 AM
merric
I have not decided on which engine i will be using, my choices are, OS 120 surpass with pump, satio 125, Asp 120 fs i have all of them laying around, any suggestons?
oriole
My Feedback: (19)
oriole's Avatar
ORIGINAL: Asanders
Agreed! The other thread is more of a hodge podge of comments, and positive/negative critiques.
Looking forward to your build.
Oriole
Old 03-18-2013, 10:14 AM
merric
ORIGINAL: oriole
ORIGINAL: Asanders
Oriole
thanks for the encourgment, i just wanted a tread about building
Old 03-18-2013, 04:35 PM
Asanders
Asanders's Avatar
Nice pics. good to see them. Plane looks pretty good. Personally I prefer Saito 4 strokes. What retracts are those?
Old 03-18-2013, 07:37 PM
merric
they are the e flit 81 degree electrics, with the 109 struts.
Old 03-20-2013, 03:14 PM
merric
so i modified the cockpit a little to make it look a little better then it was.
ID:	1864612   Click image for larger version
Old 03-20-2013, 03:31 PM
merric
i used super rc z 56 canopy glue to put on the canopy, i like using this stuff because it wipes off with water when you first put it on and it dries clear. i use elastics to keep the canopy from lifting it ensures a good fitment, well it works for me.
Old 03-20-2013, 05:09 PM
merric
started on the landing gear, here is a pic of one wing with the covering cut and one without.
ID:	1864670   Click image for larger version
Old 03-20-2013, 05:26 PM
merric
The 60 - 120 81-Degree BF 109 Strut-Ready Main Electric Retract by E-flite (EFLG509) with the 60 - 120 BF 109 Main Strut Set by E-flite (EFLG510109). They went in pretty easy, i had to cut away a little of the plastic on the inside to get cleareance for the pin the use to keep it together. The blind nuts were pre installed and alligned perfect with the mounts. the hardware that came with the retracts were of good quality allen heads. All and all one of the easiest set a retracts i ever put in, plug and play. I powered them up, they move with authorty no slop or play, little noisy but no more then what a reall plane would be.
ID:	1864677   Click image for larger version
Old 03-20-2013, 07:02 PM
kahloq
kahloq's Avatar
Have the plane....just watching what you do.
Old 03-21-2013, 08:15 PM
merric
ORIGINAL: kahloq
kahlog what engine are you running.
Old 03-21-2013, 08:17 PM
merric
kahlog what size engine are you using?
Old 03-22-2013, 03:22 AM
kahloq
kahloq's Avatar
ORIGINAL: merric
ORIGINAL: kahloq
Eflite power 90 on 8s
Old 03-22-2013, 05:12 PM
vertical grimmace
vertical grimmace's Avatar
Not engine, motor! lol
Old 03-22-2013, 08:21 PM
Jimmy Bananas
My Feedback: (13)
I'm Running a motor,engine, whatever and it's a Saito 125 4 stroke.....I love the smell of nitro early in the morning....................
Old 03-22-2013, 09:22 PM
merric
ORIGINAL: Jimmy Bananas
how does it fly with the 125, any c of g issues.
Old 03-23-2013, 09:18 AM
nh4clo4
My Feedback: (33)
I am looking at the angle the retracts are from the leading edge. Does the wheel fit parallel in the wing or is it canted slightly?<div>Ed</div><div>
</div><div>I have a 120fs that needs a home.</div>
