How free are your wheels?
Old 04-02-2013, 08:46 PM
Dig it
Dig it's Avatar
Default How free are your wheels?
Just curious as to how easily your wheels rotate. Mine do have some friction, not a lot but noticeable. Should I be adjusting them somehow?
Dale
Old 04-02-2013, 09:12 PM
bcovish
My Feedback: (8)
bcovish's Avatar
Default RE: How free are your wheels?
Do they have bushings or bearings? mine has bearings and they are really free
Old 04-02-2013, 09:33 PM
Dig it
Dig it's Avatar
Bushings
Old 04-03-2013, 05:41 AM
joeflyer
My Feedback: (48)
Lube them.
Old 04-03-2013, 10:45 AM
Gordon W
Gordon W's Avatar
I have Dubro low bounce wheels on the mains on my Nano Boomerang. The wheels rotate freely, but the tyres are soft, and wheel drag on the ground has a useful slight braking effect. I like this setup as I don't have wheel brakes and the ground handling is just fine, with taxy thrust being easy to find, whilst the plane rolls to a stop nicely on landing despite residual engine thrust. For a very short time I replaced the Dubros with some "jet wheels", again unbraked, and these were so free rolling that the jet didn't want to stop, so I replaced the tatty old Dubros and restored the ground handling.
If you use brakes - I don't know if brakes are mandatory in Canada but they're not over here - then lubing the wheels will be OK, but without brakes I wouldn't bother
Gordon
Old 04-03-2013, 11:04 AM
Dig it
Dig it's Avatar
I'll try some 3in1 oil, unless there are other suggestions?
Old 04-03-2013, 11:14 AM
rhklenke
My Feedback: (24)
rhklenke's Avatar
ORIGINAL: Dig it
I would use something heavier than 3-in-1 oil - like high-temperature grease. Jets have higher takeoff and landing speeds and thus have more of a tendency to either spin off the lube or burn it off. Its important to inspect and lube bushed wheels on a jet - if you don't, you run the very real chance of the bearing galling on the shaft and locking up. I have seen that several times before and depending on when it happens, the result can be unpleasant.
Many jet wheels use oilite bushings to help alleviate this problem...
Bob
Old 04-03-2013, 12:15 PM
Dig it
Dig it's Avatar
Sounds good. I'll see what I can find. Any brand names you can suggest?
Old 04-03-2013, 01:28 PM
shepp
"White lithium grease". Available at any auto parts house, a small tube lasts years.
Shepp
Old 04-03-2013, 01:34 PM
Dig it
Dig it's Avatar
I'll give it a try, thanks
Dale
Old 04-03-2013, 01:38 PM
rcjets_63
rcjets_63's Avatar
Mine are BVM and they sure aren't free!
Old 04-03-2013, 03:05 PM
joeflyer
My Feedback: (48)
I've been using automotive silicone grease to lube my axles andbrake o-rings for years. It works great and is available at any auto parts store.
Joe
