DIY 1/4 CARS RCMK 600B
BC, CANADA
RE: DIY 1/4 CARS RCMK 600B
why do offshore manufacturers insist on using the 5b platform for everything other than there are probably warehouses full of clones available dirt cheap.
i see a shaft driven 4wd conversion...shame they didn't put in any effort to actually come up with something new instead of flogging an old dead horse who's platform is a long way short of great.
made by who knows but marketed by fidracing.com an gtbracing.com (same company with 2 names)
Whatever happened to the day when quarter-scale cars were made of welded steel tube and alloy.
This thing looks like it's 90% plastic.
Insert big YAWN here.
If people want a plastic car they buy small scale stuff.
Now can we get back to something interesting, like your welded tube and alloy home-build Moo. It's far more impressive.
it looks a bit like a baja yes but is you look closer it's totally different ... its not just a converted baja chassis ia a lot wider to start with ... front c hubs look like losi 5 or rampage etc
im keen to see more of it ...
show me where you can buy a off the shelf 1/4 scale 4wd with a twin in it ??????
i think this look great !!
ORIGINAL: mooman007uk
<p class="tgt" style="margin: 0px 0px 0.4em; padding: 0px; border: 0px; font-size: 14px; line-height: 21px; color: rgb(43, 43, 43); font-family: arial, sans-serif; background-color: rgb(250, 250, 250); ">Used to be a partnership</p><p class="tgt" style="margin: 0px 0px 0.4em; padding: 0px; border: 0px; font-size: 14px; line-height: 21px; color: rgb(43, 43, 43); font-family: arial, sans-serif; background-color: rgb(250, 250, 250); ">Split between now</p><br type="_moz" />
This is RCMK 600B
<a href="http://img02.taobaocdn.com/imgextra/i2/74343806/T2EanLXeFaXXXXXXXX_!!74343806.jpg">
the twins engines is FID</a><span style="color: rgb(43, 43, 43); font-family: arial, sans-serif; font-size: 18px; font-weight: bold; line-height: 27px; background-color: rgb(250, 250, 250); ">transformation</span><br type="_moz" />
This is the FID 4wd concept, and by the looks of it this a prototype with 3d printed plastics.
Correct me if i'm wrong FID but being an engineer i kinda recognize prototype stuff pretty easily, just don't tease us actually make this thing please!
<span style="background-color: rgb(250, 250, 250); ">FID 4WD</span><span style="color: rgb(43, 43, 43); font-family: arial, sans-serif; font-size: 18px; font-weight: bold; line-height: 27px; background-color: rgb(250, 250, 250); "> will continue to update Thanks !</span>
BC, CANADA
ORIGINAL: mikeinoz
I cant see one bit of that car that is from a baja, the only resemblance is it has 4 wheels.
looks good , but that front bumper will crumble really bad , in a crash , double side fuel tanks is interesting , looks nothing like a hpi baja .
I like the individual parts and the project as such...... but I think the overall look and proportions are horrible [&:]
Bigger wheels and different roofline would probably make it look better.
Then again I suppose it's a good idea to see how it handles first and worry about the cosmetics later....
Will keep watching to see where this goes.
And no, I couldn't design anything like this myself, but I still have opinions
i cant read chinese , it looks like the head gaskets were removed and smeared on some gasket silicone instead ? thats bad. motor is going to get really hot with a very tight squish like that
BC, CANADA
the rcmk gaskets are pretty thin, about half of a 4 bolt zen, but it will still decrease the squish a few thou...
personally i'd use gaskets to goo, properly torqued they don't leak, if i do use goo i use just enough for a very thin layer on each surface so i don't get goo squidgeing out the seams, seems like quite a lot in the pictures...it doesn't take much to squidge out to disrupt the airflow thru the transfers
i looks like a chrysler 300 station wagon weighed down at the back with groceries
i'm interested to see it run... and stiffer rear springs should help some
I knew it reminded me of something but couldn't put my finger on it.
