1200 mah nimh battery charge volts mh?
OH
I have 1200 mah nicle metal(ofna mdp) batterys in my buggys, I use a MRC super brain 959. what should the volts and mah be set at? also there is one more setting what is it??
RE: 1200 mah nimh battery charge volts mh?
I'm guessing it's a 5 cell receiver pack from the mAh and the fact that you're posting in a nitro forum. I set mine to 1.5 C or capacity. Since your capacity it 1200 mAh, then charge current would be 1.2 Amps to 1.8 Amps. (My duratrax intellipeak digital isn't quite as accurate to set.) I don't have a superbrain, but I understand that you must also set the deltra peak voltage to as low as possible. Somewhere around 0.4.
