DLE 55 electric starter
Old 05-11-2013, 06:23 AM
DrScoles
My Feedback: (18)
DrScoles's Avatar
Default DLE 55 electric starter
I just installed this on my top flite fw190. Pretty cool set up, no instructions. Did a quickie photo series. Its available from milehighrc.com
File Type: pdf
Old 05-11-2013, 06:26 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
Default RE: DLE 55 electric starter
I have one on my EME 55. Works flawlessly.
Old 05-11-2013, 01:16 PM
av8tor1977
av8tor1977's Avatar
Well that's a pretty neat product for a very good price, and you made an excellent presentation of it.
I guess some of the scale guys would like it, as I would for a sport plane myself just for grins, but the 3D guys won't want the weight.
Cool.
AV8TOR
Old 05-11-2013, 02:27 PM
Whistling Death
Whistling Death's Avatar
They sell the starter and the controller separately. Why?
Old 05-11-2013, 06:42 PM
Chris Nicastro
Chris Nicastro's Avatar
I had to add 1lb14oz to the TF GS Corsair. How heavy is this set up with the battery you picked?
Old 05-11-2013, 07:54 PM
dasintex
My Feedback: (10)
dasintex's Avatar
What Size of Battery does it require? Volts & Mah?
Old 05-11-2013, 09:16 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Hi, Chris. Mike here. We met at the Flying Heritage Collection a few weeks ago. I have one of these starters on a DLE55 in a TF GS P-47. I use a 1800 mah 3S LiPo that will give 150+ starts on a charge. I was able to remove ALL of the nose weight. If you put the battery up front ahead of the firewall, you should be able to lose all of your ballast.
Old 05-12-2013, 04:44 AM
SWORDSN
My Feedback: (13)
Who sells them and what is the cost?
Old 05-12-2013, 04:47 AM
SWORDSN
My Feedback: (13)
Never mind I see it in the first post.
Old 05-12-2013, 06:26 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
For those inquiring about the weight of the system, the starter, battery (3S 1700 mAh), and relay added 1.1lbs to the nose of my ESM Fw-190. That allowed me to remove all of my ballast so it was a net weight gain of about 1 oz in the nose.
If you don't want to pay $30 for that controller, it's easy to rig up a system using a switch and an SPDT relay that will cost you all of $5. That's what I did since when I bought mine they had not release the controller yet.
Cheers to the OP for the nice write up!
Old 05-12-2013, 09:25 AM
av8tor1977
av8tor1977's Avatar
1.1 lbs. is quite a bit actually. I wonder why they used a heavy, old tech, brushed motor??
Also, I think whomever designed it should have made it wider in one area or added a brace somehow so that it would automatically sit square on the engine. The OP's instructions show how it needs to be mounted square; this would be very important because it determines the gear lash between the reduction gear on the starter plate and the reduction gear mounted on the engine shaft.
But, all in all it is still neat. Could someone tell me what the outside diameter of the front snout on a DLE 55 is?? (Where the starter mounting plate goes.) I want to see if it will fit any of my engines that are not DLE 55's.
AV8TOR
Old 05-12-2013, 10:42 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
It's not that much for a short nosed warbird that need the nose weight anyway. Might as well add ballast with something functional.
Old 05-12-2013, 11:43 AM
av8tor1977
av8tor1977's Avatar
Very true.
Front bearing snout outside diameter dimension anyone??
AV8TOR
Old 05-12-2013, 04:08 PM
capnduane
capnduane's Avatar
My EME 55 is 1.54ins, 39.2mm outside diameter.
Old 05-12-2013, 04:22 PM
chadxp1
is there a one way bearing in the idler gear or final gear? Obviously adding gears is going to rob power from the engine but Im not sure how much. You could even set this up to recharge you battery's if where a generator
Old 05-12-2013, 04:30 PM
capnduane
capnduane's Avatar
Starter has one way bearing. http://www.milehighrc.com/EME_E_Start.html
Old 05-12-2013, 09:32 PM
av8tor1977
av8tor1977's Avatar
ORIGINAL: capnduane
Is that a misprint? Do you mean "DLE" 55? If so, thanks!
AV8TOR
Old 05-13-2013, 03:33 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
No, he means EME. The DLE has the same dimension though.
Old 05-13-2013, 10:52 AM
av8tor1977
av8tor1977's Avatar
AV8TOR
Old 05-13-2013, 04:36 PM
dasintex
My Feedback: (10)
dasintex's Avatar
Would Pnuematic Brakes on the Main Gear on any of the 50cc size Warbird, like the TF FW190, P-40, etc; be enough to hold the Plane while the Engine ran up a bit, the reason I ask, how cool would it be if you had one of these Electric Starters in one of the these Warbirds and from your Radio you could totally start the Engine, run it up and taxi and take off without ever having to hold the plane, talk about a scale presentation.
Old 05-14-2013, 12:32 PM
av8tor1977
av8tor1977's Avatar
I am afraid that two things would likely happen. One, since nearly all WW2 warbirds were taildraggers with the exception of the P-39, that when trying to run up the engine just against wheel brakes the airplane would just nose over and destroy an expensive prop. If that didn't happen, the wheels would almost certainly just slide when high power was supplied.
A while back I saw a video of a plane sitting on one of those big wooden starting stands. The stand was about 3 feet high or so, and had wheels on the front two legs, but not on the back two legs. It had two wood vertical uprights that the wing went up against. The guy starts up the plane, steps back from the stand, and adds power. Incredibly, he taxied the airplane AND the stand it was on to about 40 feet away. Even more incredibly, he then added rudder, turned the stand around, and taxied it back. This was all on a grass field where it would be tougher to drag the stand than it would be on pavement.
I just looked for half an hour and can't find that video. Anyone else here seen it?
EDIT: Never mind, I found it. I was wrong, it only has one back leg without a wheel that gets drug, but still....
Check it out: http://www.youtube.com/watch?v=dGfvi...layer_embedded
AV8TOR
Old 05-14-2013, 01:09 PM
dasintex
My Feedback: (10)
dasintex's Avatar
ORIGINAL: av8tor1977
AV8TOR
Yes, thats exactly what I figured would happen, nose over for sure, but how sweet it would look if it would work!
Old 05-14-2013, 03:00 PM
av8tor1977
av8tor1977's Avatar
Maybe a tail hook device like carrier planes?? That could hold the plane while you ran it up....
AV8TOR
Old 05-14-2013, 05:06 PM
Todd D
My Feedback: (51)
Todd D's Avatar
ORIGINAL: irocbsa
I want one of these for my TF GS P47, are you able to energize the SPDT relay to start to motor from your transmitter, or is it a physical on/off switch on the plane?
Old 05-14-2013, 05:21 PM
irocbsa
My Feedback: (12)
irocbsa's Avatar
The relay is a energized by a momentary switch that is depressed by a servo connected to the momentary switch on my transmitter.
