QUESTION ABOUT FLYWHEELS! I NEVER EXPECTED THIS!
I have a Kyosho Inferno TR-15, and I just bought an O.S. .15CV-X engine (you know, the one with the cubical blue head and the pull-start). Well, I'm having trouble getting it installed.
Question: Can I simply slide the flywheel onto the engine? Or do I have to add something in there to get the flywheel to spin with the engine's driveshaft? With the original Kyosho GS-15R engine, there was a black washer that had a rectangular hole in the center that fit around the GS-15R driveshaft. On the outer border of the washer, there was a little notch in which one of the two pins on the flywheel fit. That caused the flywheel to spin with the engine.
Do I need something similar to this with the O.S. engine? If not, what will get the flywheel to spin with the engine? And if I DO need a part, what do I need?
Basically, someone please HELP! Tell me how to get it so I can run this engine with my Inferno TR-15!!!!
RE: QUESTION ABOUT FLYWHEELS! I NEVER EXPECTED THIS!
It sounds like you need a COLLET. It is kind of unclear of what you have, so pictures would help, but what it sounds like is that you need a collet.
