YS Engines Support Direct support from YS Performance Engines by Dave Shadel
140L compression
Old 06-05-2013, 09:51 AM
jabowil-RCU
My Feedback: (9)
Default 140L compression
I have a 140 L that I bought used and had serviced about 2 years ago by YS and it has been sitting in a closet since.
Just got it out to put in a plane and found it has very little compression. Does that seem normal?
I will try to start it this weekend on the bench which will be my first time to run it.
thanks in advance
Old 06-05-2013, 01:34 PM
Jimmy Skids
Jimmy Skids's Avatar
Default RE: 140L compression
A lot of times they will seem low on compression until you run them. Give it a run first and after running try to move it over by hand and you should see/feel some compression.
Jimmy Skids
Old 06-05-2013, 04:32 PM
petec
My Feedback: (58)
petec's Avatar
Ditto on what Jimmy said. Also after a long lay up period like that I also pull the valve cover to make sure the valves aren't sticking.
Old 06-05-2013, 05:27 PM
jabowil-RCU
My Feedback: (9)
yep the rocker arms don't move when the prop is turned.
any suggestions to repair it?
thanks,
Old 06-10-2013, 08:54 PM
petec
My Feedback: (58)
petec's Avatar
I use raw fuel and my thumb. Pull the rocker arms, soak the valves down with fuel, and gently push down on the valves to get them to start moving. If that doesn't work then pull the head and soak it for a while in fuel and then work them back and forth.
Old 06-12-2013, 01:32 PM
jabowil-RCU
My Feedback: (9)
Both valves will push down by my thumb, but the pushrods don't cause the rocker arms to move when the prop is rotated.
Old 06-19-2013, 06:04 AM
petec
My Feedback: (58)
petec's Avatar
Sounds like the lifters are gummed up. Pour some raw fuel down the pushrod tubes and let it set for a while. Then hold pressure on the pushrod side of the rocker while spinning the crank. They should free up. The other thing would be to send it in for a going over.
Old 06-19-2013, 10:15 AM
jabowil-RCU
My Feedback: (9)
OK and Thanks for the suggesstion. I will give it a try.
