56 cc pitts python bull dog
any pointers for my maiden flight as this is my first giant scale plane only ever flew 7.5 cc glow engine planes before?
How much biplane experience do you have? This is likely to be more of an issue than the size of the plane, big planes are if anything easier to fly. Having said that there's usually a bit of a pucker factor when you first put a big plane into the sky!
Biplanes are a lot draggier than other aircraft, so you can't just cut the throttle and glide in, you need to keep some power on all the way down.
Are you a member of a club? If so is there anyone who is able to assist first time up? You don't say how much experience you have so it's hard to position a reply
Terry
Terry
My Feedback: (158)
Those 4 ailerons are super responsive,, you'll see
mine after the repairs,,
http://www.rcuniverse.com/forum/cras...l#post10980433
Normally mine are the same or real close too,, but with the huge control surfaces on 3D type planes I add a little more on HR,
And I would highly recommend not going with high rates right off the bat, get a feel for it first. That thing will rotate faster than you can count.
