New DLE 20-RA
Old 10-12-2013, 01:17 AM
mpascual
Default New DLE 20-RA
Received last week, i've tested the new DLE.
868g. all included.
New RCEXL A02 #6 ignition with spark plug cap angled at 120º
Now i'm testing the engine on a bench to finish the break-in and to take rpm numbers.
Sweet running, easy adjust, nice look, and good power. Easy fit on WWII warbirds with no cowl cutting !!!
WELL DONE, DLE .....
I really love this little engine, and i'm impressed with current DLE production. On single cylinders, we have now available two options on 20cc class, side/rear, the 30cc side and 35 rear, the 55 side/rear, the 85 side, the 60 twin, the 111, 170, the 222 four, ..... What else ?
Soon we will see more DLE creations.... and some amazing surprises ..
Best regards
Old 10-12-2013, 05:54 PM
w8ye
w8ye's Avatar
Looking & sounding good
Old 10-12-2013, 07:28 PM
CustomPC
CustomPC's Avatar
I have one on order which should be delivered tomorrow and will be powering a Hangar 9 ME 109.
Old 10-12-2013, 08:45 PM
Gitano
OMG!! that's really nice! I have a DLE 35 RA and I dream for this 20cc beauty!
What prop size is swinging?
When I get one, I will use an Xoar 15x8...
Please let us know the rpm numbers of your tests... thanx!
Old 10-13-2013, 04:32 AM
w8ye
w8ye's Avatar
I only have a DLE 20 side exhaust and it likes a 16 X 8 for general fly around.
Old 10-14-2013, 08:43 PM
rye
My Feedback: (10)
i have the side mount and love it, just order the rear mount muffler 20ra for my gaint super sportster i am scatach building 72 " wing
Old 10-15-2013, 07:34 AM
Tailspin
Tailspin's Avatar
I've been flying my old 80" Hanger 9 PT-19 with the new DLE 20 rear exhaust for 3 weeks now. Performance has been outstanding! It started and ran great with no adjustments at all. Using a 17x6 Valley View wood prop the plane flies much better than with the 1.20 4-stroke glow engine I used in it before. I couldn't be happier with this new engine! Another good feature is with the rear exhaust the engine will work in narrow cowled planes like the PT-19, Tiger Moth, Ryan STA, lots of warbirds etc.
I'm ordering another one for my H-9 Tiger Moth this week.
Steve
Old 10-15-2013, 10:57 AM
Tone Price
Tone Price's Avatar
For those looking for an unboxing and comparison:
http://www.youtube.com/watch?v=rNnErVtf7g4
Old 10-15-2013, 12:29 PM
Lifer
Lifer's Avatar
Nice video. Thanks!
Old 10-15-2013, 04:11 PM
CustomPC
CustomPC's Avatar
Are the exhaust ports the same on the DLE20RA and DLE35RA?
I know the muffler outlets are not the same and there is no TBM silencer option for the 20RA.
I had the idea of trying a 35RA muffler with TBM silencers on the 20RA. If it fits, In theory it should be quieter with similar back pressure to the stock muffler.
Old 10-15-2013, 08:00 PM
bcchi
I like the xaor 17x8 on the DL20&VV 17x6 on the VV 20.
BCCHI
Old 10-15-2013, 10:01 PM
Gitano
How many rpm are you getting with 17x8, 16x8 or 17x6?
Does 15x8 will be to short?
Old 10-16-2013, 12:01 AM
mpascual
DLE20 and 20RA have the same exhaust pattern, same size, gasket and M4 bolts.
Best regards
Old 10-16-2013, 08:36 PM
bcchi
BCCHI
I do not check rpm much just put on prop fly the airplane if pulls like I want -great joy.I think 15x8 would not be enough prop for DLE 20.I like 17x8 xaor or 17x6 VV.
BCCHI. AMA 2500
Old 10-17-2013, 05:05 AM
flyboy57id
My Feedback: (14)
Hi Guys
has anybody taken any noise readings of the Dle20RA with the stock muffler? Our club has a maximum noise reading of 95db at 10 feet!
Gordon
Old 10-20-2013, 09:49 PM
CustomPC
CustomPC's Avatar
Hi,
Can those that have the DLE-20RA please check your engine and tell me if yours has any play and clicking noises like in my video below.
http://www.youtube.com/watch?v=lHZ9xFHROgk
Old 10-21-2013, 04:52 AM
w8ye
w8ye's Avatar
That is the clearance of the rings within the ring lands on the piston. It is normal and means nothing. You will find that on all single cylinder engines
Old 10-21-2013, 05:12 AM
CustomPC
CustomPC's Avatar
Thank you for that gold nugget of information. You're right.
Now that i knew where to look. I took the muffler off and watched the ring as i rocked the prop and can see (and hear) the ring move in the lands and squeegee out some oil as it does so.
The noise is not so pronounced when the engine is hand-held. Adding the muffler and the metal test stand amplified it quite a bit.
Thanks for the help. Much appreciated.
Old 10-21-2013, 04:03 PM
w8ye
w8ye's Avatar
I know because I've been there and done that - seen it for myself.
Old 10-30-2014, 05:47 PM
slamn sammy
slamn sammy's Avatar
I have a DLE20RA and was flying to day and the spark plug blew out and striped out the threads out. Can it be repaired? Can l find parts? HELP!
Old 10-30-2014, 06:08 PM
captinjohn
868g. all included.
Best regards
Just wondering if one of the new DLE engines is going to be a 4 stroke ? That would be a surprise ! Capt,n
Old 04-28-2015, 04:38 AM
wallacemartinss
Hello Friends, i have same problem our friend (CustomPC). The problem happened after the engine break-in process.
https://www.youtube.com/watch?v=5TmLJzLs3-c This is really normal?
Old 04-28-2015, 11:08 AM
pilotpete2
pilotpete2's Avatar
You can buy a new cylinder head for $64.95 from Tower, or have someone install a helicoil to repair the cylinder head.
Sounds like you over torqued the plug and damaged the threads. I would not be very hopeful of the warranty covering it;-(
Pete
Old 04-28-2015, 11:42 AM
wallacemartinss
Pete
Pete, but the engine is running normally ...this will give me problem?
Old 04-29-2015, 05:29 AM
slamn sammy
This is normal with the 20 BUT! sounds like you have lost compression, If your using the stock spark plug throw it away and replace it with a NGK CM-6. I had to send my 20 back because the stock plug pulled the threads out of the head. Lucky it was still in warranty! The nocking is just the piston rod rocking at TDC.Looks good
