A little help..
11-08-2013, 05:52 PM
A little help..
Ok guys, I got just got a dx8 and an 8c reciever, and I have a plane with two elevator servos, now the problem is I can mix one ( elevator) servo with the other elevator servo (aux1) and they both will move in the same direction, no big deal.. But when I set up another mix setting to have one elevator go up, and the other go down, it won't work. Is there anyway to get around this?
11-14-2013, 05:36 AM
ON, CANADA
Are you trying to get elevons??
11-14-2013, 11:01 AM
DX8, if its similar to the DX18 programming you set up dual elevators in the wing type menu.
I'm guessing the way you have it set up now trim probably only works on the master as well.
11-14-2013, 02:18 PM
MI
Why would you want one elevator to go up and the other to go down??
11-15-2013, 07:17 AM
LOL I didn't read that all the way apparently, I thought when he set up a mix it was causing one to go up and one to go down
11-15-2013, 08:20 AM
MI
LOL, Maybe he will explain ?
