Brison BA5-8 95cc gas
Recently obtained a Brison BA5-8 95cc gas engine. Can any one tell me the proper oil/gas mix, synthetic or non synthetic for break-in and flight. Also are prop. and back plate drill guides available for this motor? Thanks.
NC
Pennzoil aircooled oil from Advanced Auto 32:1 or 4 ounces to a gallon of 93 octane gasoline. The prop dpending on your particular application should be a Xoar 24X10 two blade or a Mezjlik 22X12 three blade. The spinner backplate will be a single bolt 3/8 diameter no drill guide required. These Sax/Dolmar piston and cylinder take along time to properly break in unlike the alphabet engines. Good-luck
