Dreamworks GSF-150 with Jet Tronics Dual Valve
I have installed the GSF-150 failsafe with a Jet Tronics Dual valve in my Reaction X gear system. The GSF works according to spec and the Dual Valve works to operate the gear. The problem is, they don't work together. Currently I use the GSF as a pressure gauge and the Dual Valve operates the gear. Try as I may. I have not found the process to have the Dual Valve listen to and function with the GSF. The GSF is advertised to work with electronic valves and is not intended to drive a servo for gear function. I find the reverse to be true. Has anyone had success using the GSF with the Jet Tronics Dual Valve?
My Feedback: (24)
When setting up the GSF150 trigger points, the low pulse width must be set to gear down. This is the most common error we see when programming. No issues should arise with electronic valves.
Todd, I entered a note in the DreamWorks Forum explaining the situation. The GSF, with the pulse width at 1100 gear down and 1900 gear up, works fine when I connect it to a servo. The Jet Tronics valve also works correctly when I eliminate the GSF from the system. They do not work together.
Dreamworks should have tested this combination before they put it up for sale.
If it does not work with Jet Tronic valve, it becomes a very expensive pressure gauge.
My Feedback: (24)
Of course it has been tested... We have hundreds of these units in the market, working perfectly with all brands of electronic valves. Both, the failsafe and the valve require programming for correct operation. One other note: Air pressure in the system must be above set failsafe trigger for gear to cycle...
Pay attention folks!!!!!!!!!!!!! I went through the sequencing of the GSF with The Dual Valve again and I am pleased to inform you that the system does work. Thanks Todd for hanging in there with me. The very first thing I did, since I only have two hands and my wife is at work, was to make a tool out of some scrap light ply. The tool simultaneously depresses both buttons on the Dual valve while I turn on the Transmitter and Rx with my other hand. This procedure resets the dual valve to factory settings. An initial requirement before setting the valve trigger points. My guess is if you take the dual valve as received from DreamWorks, the reset procedure would not be necessary. But just to be sure it won't hurt to reset it anyway. The tool works well to insure both buttons are depressed when the power is turned on or you'll need someone to turn the power on while you use both hands to hold the dual valve buttons in.. The system air was 75 psi. where I was sure I was above the set fail safe of 50 psi. I should mention that the GSF had been set up per the manual before I did the sequencing of the dual valve.
In my efforts to make the GSF and the Dual Valve work together I found that it is most important to make sure the valve is reset to factory settings. Pushing both buttons on the valve simultaneously while turning the power on can be problematic but must be done correctly to prepare the valve to listen to the GSF. The tool I made looks like a two prong fork but was the ticket to get the valve reset.
My Feedback: (24)
Typically, the Jettronics valves will work with a correctly programmed GSF-150 out of the package. However, if it does not, you simply program the trigger points following the valve programming instructions. Simple method of resetting the Jettronic valve is to hold both buttons and turn on the RX.... Then reprogram as per manual.
"Hold both buttons and turn on the Rx" that is where I found the problem. I just couldn't find a way to push both buttons with one hand while turning on the RX with the other. That's where my little forked tool came in. At that point the system functioned properly.
