~NEW~ Yokomo DIB Ver. RS Blue Edition
New from Yokomo the DIB Ver. RS Blue Edition is now are Banzai Hobby!!!
Using resin materials, high spec yet reasonably priced!
Off course you can use DIB parts to pimp it up as you require.
Main Specifications
■ Belt drive 4WD system
■ Aluminum motor mount front and rear bulkhead center bulkhead
■ Front One-Way
■ Rear Spool joint
■ Drift dedicated steering system
■ Vehicle height adjustable oil damper
■ Drift dedicated multi-turn spring
■ Universal shaft
■ Aluminum Turnbuckle tie rod and upper arm before and after
■ Clamp type hex hub
■ Full ball bearings
For more Specials and Updates please Join us on Facebook!!!
Banzai Hobby Team
Main Specifications
■ Front One-Way
■ Rear Spool joint
■ Universal shaft
Banzai Hobby Team
