~NEW~ Yokomo Drift Package Gear Diff & Accessories
New from Yokomo the Drift Package Gear Diff & Accessories now at Banzai Hobby!!!
The new Gear Diff and Accessories for the Yokomo Drift Package is here, if you want smoother an stronger diffs for your Drift Package then look no more!!!
Drift Package Front Gear DiffDrift Package Rear Gear Diff
Gear Diff Unit for DRIFT PACKAGE
Maintenance Kit for DRIFT PACKAGE Gear Diff
Steel Drive Cup for DRIFT PACKAGE Gear Diff
Gasket for DRIFT PACKAGE Gear Diff
Bevel Gear Set for DRIFT PACKAGE Gear Diff
40T Ring gear/Diff Case for DRIFT PACKAGE Gear Diff
O-Rings for Gear Diff DRIFT PACKAGE Silicone 4pcs
Please join us on Facebook for Weekly Specials and Updates
Banzai Hobby Team
Banzai Hobby Team
New Drift Accessories for the Yokomo DIB and Drift Package
Aluminium A-Arm Narrow Steering Block 0° & 7°
Rod End Adapter for Lower A arm with Narrow Steering Block 15 and 18mm
53mm Universal Shaft for Narrow Steering Block
Please Check us out on Facebook for Weekly Specials and Updates
Banzai hobby Team
Banzai hobby Team
More New Goodies from Yokomo
Narrow Steering Block (0°) for Aluminum A Arm
20mm Rod End Adaptor for Upper A Arm with Narrow Steering Block
23mm Rod End Adaptor for Upper A Arm with Narrow Steering Block
Please come check us out on Facebook for Weekly Specials and Updates
Banzai Hobby Team
Banzai Hobby Team
