Skymaster A-10 1/7 scale help
Hi,
can some one please post a few photos of there internal set up of the model listed above. Only 1:7 scale need to apy please. A photo of your tank placement and mounting would be appreciated. This particular model I am not sure where I should be placing the main tanks. All the treads I have looked at so far have not showed any internal photos of use.
Ivan
Ivan
Have you looked at the thread on regroups about this model?
Ill try and get a pic of my tank layout, but If i recall correctly, i put the tanks between the formers and the rear formers are sufficiently tight that the tanks can't go much further back. The position of the former rather helpfully puts the centre of the tank over the CG.
I added some ply to both front and rear formers to give a more stable mounting platform.
I aeropoxied a couple of the 90 servo mounts to the front of the tank so that I could screw then into the front former.
For extra security I used silicone glue to secure the rear of the tanks to the rear former.
Hope that helps
Hope that helps
HI bidrseed2,
I have looked at RC Groups and the only ones I seem to be seeing are the ducted fan units not turbine. Thank you for the information. Centre of tank over the C OF G sounds good to me. If you can get a pick of the lay out that would be much appreciated.
Ivan
Ivan
Hi Justfly
Ok there are 2 option for you to have a look. Try to watch Bob's videos on youtube and yes you can take out the one former on the bottom to fit you tanks in. Replace the former to support the fuzz at a different point. There are a lot of changes to do you'll find out, but a great little jet. Bob has a lot of good ideas and also we changed a few points on the model asswell.
https://www.youtube.com/user/hornitpilot
This is Bob's link and he is a very interresting guy.
Blue skies
Blue skies
Bob's video is of the larger A-10. I have the 1/7 scale which is smaller. Can someone please post a photo of where they put there tank set up on there plane. Bob's set up on the large one seems forward of the C of G. I would think that with all that fuel forward it would make the plane very nose heavy.
Hope that helps
Hope that helps
You will find that you need to build all the gear as much as possible in the front to keep the CG close to right because it will be still tail heavey after finishing the build. There are 2 bulkheads on the bottom of the fuzz where the fuel tanks are suppose to stand on, but I took the rear one out on the bottom and mounte the front of the tanks just behind the front bulkhead. That also give you space to do your tray for the pumps and UAV to fit in on top of the tanks. That will help with the CG before and after flights. Unfortunatly I dont have pics but will see if I can get some to post. Keep the installation forward as possible.
I understand that the install must be as far forward as possible. However I'm still up in arms about the fuel until I see for my self how others have done it. We have got a jet meet next year and hopefully someone will have one there for me to look at if no one posts any photos.
I still can't get my head around having that much fuel which = weight forward of the C of G. I would think that this would effect the flight and trim as fuel is burnt up. If this is the case that's fine but that's why I want to see for my own eyes how people with the small A-10 have done it. It would be good if Skymaster posted some photos of there tank set up when they where flying there small one.
If you build the 1/7.5 scale A10 then I dont see why you struggle cause everything is basically on Bob's youtube videos cause that's a X-treme A10 1/7.5 scale he is building with all the mods and the tanks installation.
https://www.youtube.com/watch?v=0t2r...FjjfvDjzGz4-CQ
Not struggling. Just wanted to see what other peoples opinion is. I'm putting my tanks over the C of G as bidrseed2 suggested.
