Will this Combination work if i buy it?
Hi. Im new to the forums. Im looking forward to using this site for help. Will this combination work before I Buy it? the links are shortened
http://bit.ly/1DS5Qcd
http://bit.ly/1yxqDxk
http://bit.ly/1yvKksv
http://bit.ly/1xI4zMo
Thanks in advance.
Regards,
Jhaelenn
Thanks in advance.
Regards,
Jhaelenn
Seriously? Just click it I'm Not that type of guy! Not trying to get arrested!!posting something bad would get me banned. Not helping me
I dont have much knowledge on edf jets but it seems that you are trying to fit a too big of a fan on this jet.. My suggestion is to find a plane combo that already comes with a nice, 12 blade unit that provides a nice, jet like sound with a motor and esc, and avoid experimenting combinations that can be expensive, ruining batteries.
I am sure that the electric jet guys can chime in, however in this forum most guys fly gas powered turbines.
http://bit.ly/1KUoQIW
can be wrong, but think that there are not many small diameter edfs with 12 blades... maybe you will should compromise with 8 or 10 blades
about the edf and esc combo there is a software motor simulator that can help you a lot.. www.motocalc.com it has a 30 day free test download
Jhaelenn: take a look at this 5 to 10 blade upgrade in this F-22.. is very affordable and sounds good in my opinion:
https://www.youtube.com/watch?v=qvWGDk1htjw
You should see and hear some of the multi bladed EDF units that are around.. they sound absolutely great.
http://www.ebay.com/itm/Cyclone-Powe...-/130940884081
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.ebay.com/itm/XRP-ChangeSu...-/301058944284
http://www.nitroplanes.com/95a251-f18-blue-rtf-24g.html
Is this ok?
This isn't a trolls post. You'd actually be surprised at the sounds of my previous jet. Even an actual Airman though I modified this plane with a real jet engine. It's the same plane also!
My Feedback: (38)
Ok, I didn't want to get personal, but in his first post he post a bunch of HOBBYKING stuff, then when questioned, I DONT KNOW WHY WITH SUCH A GREAT NAME like BLACK_RC_PILOt, with no post, then makes a statement about getting arrested, gets some good advice and then comes back saying he can not afford it, I offer what is known to be a decent entry level complete edf jet,that is affordable, and makes the statement that he makes his own money, WELL welcome to the real world pal, that's how we all get ours too, go out everyday to earn it. since I was 15. Then he Ask if there are fans that sound like turbines, and the answer is clearly NO, edf fans do not have compressors, or injectors, or an explosion inside a chamber, or high velocity burned fuel exhaust coming out of them, that is what a turbine sounds like. There are some good sounding fans out there but they do NOT sound like any turbine I have ever heard, and I have been around plenty of high end EDF Jets, One being an older BVM f-86 that was running on 14s it sounded good but nothing like a turbine. Period. SO after your comment telling me to shut up, I will still offer you this last bit of help, and Im done with you,, Here is a Fan I believe you can afford, You can get some jetA, SCRATCH that you will have to get diesel, put it in a squirt bottle, spray it in the fan and sit behind it using your voice making roaring noises, and You will have a electric fan that sounds and smells like a real Jet Turbine,, Best of luck to you Troll, my bet is he is under 16 years old..
My Feedback: (85)
LOL Well said.
The thing that mostly bothers me about EDF sound is the way they can go from zero to full RPM almost instantly.
Maybe an EDF pilots has to have a slow thumb to please me, or use some electronics or SW to make the throttle response slow.
