Epoxy tip
When i mix epoxy or need too. I get a small handfull of paint sample swatches from hardware store there usually the right size for mixing and easy to dispose of. Naturally when i go to the store i buy something😎
I have several bottles of cure time on my bottles. Almost made the mistake one time of mixing a five minute cure with thirty mineut cure.
sooo i tape the bottles together so that thirty minute is two bottles taped together and five taped to five. And so on...
I also tape my bottles together. When it gets down to the bottom of the bottle, I can lay the pair down on my work bench, and they won't roll off. When they get really low, I prop them up, upside down. (with the caps on, or it will make a real mess). My favorite mixing surface is the plastic lids off nuts cans, or coffee cans. After each mix, I grab a small paper towel, and wipe it off with a little acetone, or alcohol. Then it's ready to go again. They last for a long time.
For a nice slick (no sanding required) finish when you fiberglass a wing center section, just cover the freshly applied area with Saran Wrap (like use in the kitchen) and smooth it out with your fingers. You will get a perfectly flared edge and a finish as smooth as glass when you remove the Saran Wrap (of course leave in on for at least 6 or more hours to cure before removing). Be sure there are no ripples in the wrap as you smooth it out.
All the resin is the same its the hardener that determains the drying time. This is what I use when mixing a large amount. If its a little bit I use a small note pad and flat toothpicks.
http://www.mudhole.com/Rod-Building/...r-Epoxy-Mixers
http://www.mudhole.com/Rod-Building/...y-Finish-Mixer
My Feedback: (34)
Jerry
I also make Fishing rods and this Epoxy Mixer is availeable through Mudhole Rod Building Supplies. Here are my Epoxy Caddies that I made and work awesome. Also a pic of the housing i made for the mixer. HTH![](http://www.rcuniverse.com/forum/attachment.php?attachmentid=2084426)
![](http://www.rcuniverse.com/forum/attachment.php?attachmentid=2084427)
I use those small plastic cups (jello shot cups) from a party supply store usually you can get about 250 for $5.00. I like to use pop-cycle sticks as mixers bout a big box of them at Hobby Lobby a couple of years ago for a few dollars and have only used about half.
