New Tamiya Products
New Tamiya Products
New From Tamiya!!!
TT-02R Chassis Kit
This refined, race-spec version of the TT-02 chassis features a wide range of option parts and newly-designed components to make it ready to race! The included racing spec parts include upgraded uprights, motor mount, shafts, joint cups and more, while the suspension is fitted with metal parts and CVA oil dampers. It retains the TT-02's versatility and easy-to-drive characteristics.
Featured components
Aluminum uprights (3 degree toe-in)
Aluminum motor mount
Included Hop-Up-Option parts
53159 4mm Aluminum Flange Lock Nut (Blue)
54247 3x18mm Aluminum Turnbuckle Shaft (Blue) x2
54501 TT-02 Aluminum Propeller Shaft
53642 5mmAluminum Ball Connector (Blue)
54500 TT-02 High-Speed Gear Set (68T)
54502 TT-02 Aluminum Propeller Joint
This is an assembly kit. Require assembling. Modeling Skill Required.
Require Radio Gears with Servo & ESC, Batteries, 540 Motor, Body
Toyota FJ Cruiser - CC01 Orange Painted Body
The Toyota FJ Cruiser is a retro style SUV with styling and off road performance reminiscent of the original Toyota FJ40 Land Cruisers. It was first introduced to the public as a concept car at the January 2003 North American International Auto Show. The FJ Cruiser was later approved for mass production after positive consumer response and it debuted at the 2005 North American International Auto Show in final production form.
The Tamiya R/C replica faithfully captures all of the full size FJ's details down to the large headlights positioned near the center of the front of the car, chunky fenders, and a trio of windscreen wipers. The FJ body is mounted on the capable CC-01 Cross Country chassis, which features independent front suspension and a rear 4-link rigid suspension set up for fun scale trail running enjoyment. This Limited Edition special release includes a pre-painted body, making it easier and quicker for the modeler to get his machine on the off-road trails.
Require Radio Gears with Servo & ESC, Batteries.
ESC NOT included.
Dark Impact White Ver. - DF03
This 1/10 scale 4WD buggy is specially designed to excel in off-road buggy driving fun. It features a mid-rear mounted motor and longitudinally mounted battery for optimum balance for jumping. The battery itself is inserted through the bottom of the chassis, eliminating the need to remove the body, which makes routine maintenance easy and quick. The high performance shaft drive 4WD is combined with a double wishbone suspension system featuring extra-long suspension arms for improved stability and off-road handling. This version of the Dark Impact comes molded in all white parts and is only available for a short limited time.
ESC NOT included.
Sponser Sticker Set - Off Road Car
This sheet includes a variety of stickers perfect for use on 4x4 off-road vehicles.
For more updates and specials please check us out on Facebook.
Banzai Hobby Team
TT-02R Chassis Kit
Featured components
ESC NOT included.
ESC NOT included.
Banzai Hobby Team
New Products from Tamiya now at Banzai Hobby !!!
TB EVO.6 Chassis Kit - TB EVO 6 Black Version
The TB Evolution line-up of shaft drive 4WD racing machines began its lineage in the year 2000. Since that time the machines released in subsequent years have evolved. The new TB Evo 6 continues the tradition of evolution by introducing new design elements and proven parts from many of Tamiya's other 4WD touring car platforms.
The TB EVO 6 shares the same drive train as seen in the TB-04 tub chassis machine, which uses a horizontally positioned motor for optimal torque displacement balance. TRF designers have also incorporated other tweaks to bring club racers the perfect weapon for spec motor club racing. These tweaks include suspension parts from the TRF418 as well as carried over parts from the TB-04.
Aqroshot - DT-03T
In early 2014 Tamiya introduced the new DT-03 off-road chassis. For 2015 Tamiya introduces the DT-03T, which is a TRUCK variant. The platform is intended as an easy-to-get-started model to encourage young drivers to enter the world of R/C. Its intuitive yet tough design allows hassle-free assembly and gives less experienced users the opportunity to get to grips with R/C model composition and construction. The truck variant allows users to tackle bumpy street or parking lot terrain with its taller stance and wide and low profile road hugging equipped tires.
TRF Big Bore Damper - 4pcs
These big-bore dampers are now available for purchase as a set - they were originally included as a part of the high-end TRF419 chassis kit. Big bore dampers have an increased cylinder volume, allowing more oil to be inserted and endowing your chassis with improved grip.
Contains parts for 4 dampers.
Damper cylinder diameter is 0.5mm wider than standard dampers, allowing 10% more oil.
Aluminum parts are blue anodized.
Aluminum Big Bore Damper - M-Chassis (4pcs)
ESC TBLE-03 Brushless - Sensored or Brushed Capable
This is a smaller footprint and lighter model of the Tamiya TBLE-01s electronic speed control (item 45047). As a smaller unit, it cuts down on room required in your chassis, contributing to a lighter model.
Dimensions: 30.4 x 37.2 x 26.5mm
Sensored brushless ESC detects motor rotor positions with precision, enabling more efficient power supply and smoother motor response.
Functions such as reverse cancel, battery cut-off, brake and neutral brake can be set separately.
Comes with a cooling fan to help slow the overheating of the ESC, allowing longer operation times and a wider range of settings.
Sensor cable is included.
Designed for use with Tamiya sensored brushless motors such as Items 54272-5.
Compatible with Ni-Cd, Ni-MH and Tamiya Li-Fe battery packs.
Note: Not suitable for use with rock crawling and twin motor-powered models.
Carbon Damper Stay Rear - TT02
This is a rear carbon damper stay for the TT-02 chassis platform. Carbon fiber parts contribute to the increased rigidity of your RC model.
Carbon fiber damper stay features a number of attachment positions to allow alteration to the shock angle.
Contains small parts for damper attachment, such as collars, screws, ball connector nuts and spacers. Use spacers to adjust damper attachment height and model ground clearance.
Compatible with TT-02, TT-02D, TT-02T and TT-02R chassis.
Note: these stays cannot be used on TT-02 Type-S and TT-02B chassis.
Carbon Damper Stay Front - TT02
This is a front carbon damper stay for the TT-02 chassis platform. Carbon fiber parts contribute to the increased rigidity of your RC model.
Banzai Hobby Team
Aqroshot - DT-03T
Banzai Hobby Team
ヾ= ̄∇ ̄)ノ NEW! Tamiya 58611 Honda CITY TURBO WR-02C CHASSIS now at Banzai Hobby
Honda CITY TURBO : WR-02C CHASSIS
This RC model is an updated release of a Tamiya classic, which was released as "Willy's Wheeler" back in 1983. It has returned upon a newly-overhauled variant of the WR-02 chassis. It is fitted with a Honda City Turbo body, which also includes a comical driver figure. The WR-02 chassis features a 2WD drive-train with fully independent double wishbone suspension.
ESC NOT included.
ESC NOT included.
