Wren 54MK3 Help please
OK long shot but here goes. I purchased a used 54mk3 and may have messed up some parameters looking for the test menu screen, (start/run/info/radio) to no avail, I managed to get to a screen when you hold buttons down while turning the rx on and it shows the words parameters and values but thats it, i dont think i touched and numbers there. All i wanted to do was test my solenoids and glow plug but couldnt find thet screen i needed so i just fired it up and hope for the best. Heres what went down, the engine fired right up no problem, once "running as per fadec i turned off the propane gave it a few seconds to stabalize (40000rpm ish) then i went to spool up. It went to about 80,000rpm and 850deg and shut down with a flame out fault, it also takes a long time to reduce temp 60deg before i can refire the engine. I know some numbers have to be messed up somewhere but how do i get back to default numbers? and where is my test menu screen?
Brian
Brian
