Lanier giant stinger
Old 01-17-2016, 10:54 AM
promag
Thumbs up Lanier giant stinger
What wonderful marriage : Giant Stinger and Zenoah G-22. Have this combination fying from more than 12 years and every fly became impressed. Plane was constructed as per plans and weighs 20 lb with wing surface 1560 sq. in.
G-62 pulls at 28 lbs thrust, 7150 RPM with Zinger 22x6-10 prop.
Of course is not a 3D plane, but does normal aerobatic very well. Lands like a dream.
People that knows the plane knows about these caracteristics.
This is my tribute to this wonderful kit out of market from long time and allways a pleasure to fly.
Old 01-17-2016, 11:47 AM
flyinwalenda
flyinwalenda's Avatar
Nice planes but carrying around those long one-piece wings gets old after awhile!
Old 01-17-2016, 12:09 PM
promag
Ia, thats truth. Mine stays at flying field, haven't this inconvenience.
Old 01-23-2016, 04:29 AM
gene6029
gene6029's Avatar
That brings back some memories! My first " big gas plane" was a Stinger with a G-62. I had a Zinger 22-10 prop on mine also. That plane introduced a lot of people to gas models. Sold mine after hundreds of flights. Built mine with a balsa turtledeck. Your correct, it really was a wonderfull kit....Gene
Old 01-27-2016, 06:07 AM
gilanne
The Great Planes Escapade 30cc MX is very similar in design.
Old 01-28-2016, 06:06 AM
Gizmo-RCU
My Feedback: (27)
Having had a Stinger and now an Escapade there are a great deal of differences in my view. Construction is not at all the same for the most part and the Escapade is very much lighter for it's size. They both fly well but the Escapade does much more on half the CC's....mine has the DLE 35ra. Don't get me wrong, I flew the Stinger to death (play on words), it's only real fault was the Crappy Lanier ABS Plastic parts that cracked after a while and it is a heavy plane.
Old 08-17-2016, 12:48 PM
TexasFlash
My Stinger fuse still sits in the rafters. If it wasn't for a dog killing the wing a bunch of years ago I'd be tempted to resurrect it at times. My G62 went from there to a Laser 200, also by Lanier, and after cracking it in half over a decade ago (when I took a break from the addiction) it's just fixing to be put back into use.
Old 08-21-2016, 03:01 PM
sbd-3
Here is the foam wing from http://www.eurekaaircraft.com/foamwings/wing-s.htm
[TABLE="width: 904"]
[TR]
[TD="colspan: 5"][HR][/HR][/TD]
[/TR]
[/TABLE]
[TR="bgcolor: #d3d3d3"]
[TD="class: auto-style2, width: 60%, bgcolor: #FFFFFF"]Stinger (Giant 84") Includes spar slots, servo lead hole, and wing tube hole (if needed)[/TD]
[TD="class: auto-style2, width: 10%, bgcolor: #FFFFFF"]$60.00[/TD]
[TD="class: auto-style2, width: 6%, bgcolor: #FFFFFF"][/TD]
[TD="class: auto-style2, width: 10, bgcolor: #FFFFFF"][/TD]
[TD="class: auto-style2, width: 14%, bgcolor: #FFFFFF"]Part #: "W4036"[/TD]
[/TR]
[TD="class: auto-style2, bgcolor: #FFFFFF, colspan: 5"]Span: 84 in. Area: sq. in. Style: Symmetrical. Pieces: 2 Pieces LE: W. TE: W. Manuf: Lanier[/TD]
[/TR]
[TD="class: auto-style2, bgcolor: #FFFFFF, colspan: 5"]RC: 19 in. TC: 19 in. Taper: 0 in. RT: 2.375 in. TT: 2.375 in.[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
Old 08-22-2016, 04:20 AM
sensei
sensei's Avatar
Sure wish I could find a giant Stinger untouched kit someplace.
Bob
Old 08-22-2016, 04:43 PM
sbd-3
I did find the plans online @ evel bay...LOL There are nice and they show the wood wing that was used in the ARF Stinger.....
Old 10-02-2016, 03:26 PM
PLANE JIM
My Feedback: (109)
They are a blast to fly-I cut my wing in half-and added a 1 1/2 inch wing tube in the thickest part from the bottom =reshetted the cut out. I lost the airplane shortly after a recent recover. I do have another new one in the box.
Old 10-10-2016, 05:29 AM
Daveb572
Hi Guys! I was fortunate enough to come across a Giant Stinger kit, (84" span), as a replacement for a Stinger 120 I lost in a house fire some years back. I'll be powering it with a DLE 60cc twin. Any advise on reinforcing, servo recommendations, or anything else you guys think I should know, would be helpful. I'm an "old school" modeler and enjoy building kits. Although this isn't my first giant scale build, it has been a while since I've had balsa scraps super-glued to my fingers.
Thanks!
Dave Bryer
Old 10-10-2016, 07:17 AM
Gizmo-RCU
My Feedback: (27)
Glass the insides of the Plastic parts to keep them from the cracking that will happen sooner or later! I built several Stingers and this was a given. I used a light Glass fabric and ABS pipe glue to
cover the inside of the parts use it as you would epoxy. When dry you can trim the edges and have the same effect as actual fiber-glassing. Be careful with the glue as it will mess-up the finish if allowed to contact the outsides and soften the plastic until dry.
This advice comes from my recollections from about 15 years. ago............It worked well for me.
Old 10-10-2016, 07:28 AM
Gizmo-RCU
My Feedback: (27)
Forgot, the fuselage is weak at the rear of the wing of the wing saddle where it has a bend on the sides going back to the tail. I used tri-stock on the insides with 30 min epoxy and flat carbon fiber on the outside hidden under the covering.
My planes dated from about the end of Lanier's ownership and some of the parts were very poor...........
Old 10-10-2016, 08:17 AM
slim69782003
I am currently building the Giant Scale (84" wing span) Stinger. Right now I am working on the lower half of the fuse and have a couple of questions... First is the Gas tank box supposed to be fully boxed and braced? I can't tell very well from the plans.
Second question, how are the Aileron Servo wires supposed to run through the wings?
Old 10-10-2016, 08:30 AM
TexasFlash
I seem to remember cutting a small trench in the foam to run the wires.
Some will say to replace the door skins with something lighter as well as the plastic turtle deck and I'd consider this on another as well, but keep in mind these always come out nose heavy and require a lot of weight on the tail to balance. Losing weight in the tail is great as long as you can do the same in the nose. On my Stinger AND Laser 200 I cut a spot under the h stabs to mount 2 6v battery packs and ran extensions to the switches. The still needed lead but less of it.
Mounting the servos in the tail is a must as well. No pull pull here as the weight is needed in the rear.
Old 10-10-2016, 09:46 PM
slim69782003
thanks for the info Flash... gives me some thoughts on where to go next.....
Old 01-04-2017, 07:00 PM
brickwoodward
I have a new in the box kit, foam wings. Need trade for a G-38 size Extra type kit? Could be other aerobatic like Edge or ?????
[email protected]
Phone- 321-268-0948, leave message and I'll call you back, Bill
