Super Tiger engines and parts?
Is there anymore word on a possible return of Super Tiger engines and parts? The last information given indicated was that possibly at the end of 2015?
bhady
bhady
TN
Bill, I have a Super Tigre 51(China) the compression is very low, I replaced the ring with the one available from Towers? what should I do?
Cylinder Liner is not available?
If the ring didn't help, then your engine likely needs a new pistion, liner, or both. Unfortunately, neither one is available. You may try running the engine to see if the ring just needs to be seated. Running the engine for a few tanks' worth of fuel at a very rich setting usually helps, with gradual leaning towards peak RPM after 2-3 tanks of rich running.
TN
Bill, Found a new ring and cyl.
put in both, I have fair comp. after 3 tanks of fuel, lists of smoke?
whats with the smoke?
i have a new piston, but did not see the point of replacing it?
