ACE Turbine
ACE Turbine
Test Video:https://www.facebook.com/mike.d.lin/...01216944703464
You can purchase it through Global Jet Club at www.globaljetclub.com or
email us at [email protected].
ACE60
ACE60
ACE120
ACE120
My Feedback: (20)
NY
hello today I went to run My Ace140. The pump was pumping in reverse when hooked up following the arrows. When the fuel lines were reversed it attempted to run, but once GSU showed fuel ramp up, a low rmp message was shown. Next attempted start showed low temp. The third start showed a starter error message in red on GSU. Powered everything of and attempted to start for the forth time and fuel started running out of the engine.
i have an event on the 14th and am hoping someone can help out with out sending engine in and not being able to fly.
please help
please help
Yesterday I flew my HSD F16,after the 1st flight, when I went to fly it for the 2ed time the ACE60 starter was running for a few seconds and then stopped, I restarted the startup procedure from fresh unplugging everything and it did the same thing on startup procedure. waited a few min then went back & tried it again didn't see the fuel moving through the line so I checked the fuel filter by unplugging the line from the turbine and running some fuel using my fuller through the tank and it came out the line good. After doing this 3 times it the turbine started with a bit of a hot start with flames coming out of the tail for a few seconds and then everything was good for the rest of the day & flew it a few more times with out problems but I'm wondering what would do this could the glow plug starter be intermittent? the ACE60 had only 4hr of run time on the turbine.
any ideas
I'll do some testing to the fuel pump and starter plug, I'd think the plug would be working since it did work and didn't give me anymore problems the rest of the day
Robert
any ideas
Robert
