Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Ignition Cut-off shutting down engine without user input
Old 04-06-2016, 06:32 AM
dingo9882
Default Ignition Cut-off shutting down engine without user input
Hello,
I am having a problem with what I think is with my power system sport plus. I believe it to be vibration induced....(I am not an engineer so I am ignorant in these matter). Basically, when I run my engine to full for a couple seconds and back to idle it shuts the engine down completely. I figured I had a bad optical kill switch, so I replaced it. Unfortunately the engine is still cutting off without any input from me. When I completely removed the optical kill switch system, I did not have the engine cut off at any point during any throttle range. The original system and kill has only had about 15 flights on it....but when I checked the may power system I noticed that the white plastic cover on the bottom had cracked completely and broken due to vibration. The problem with vibration has been fixed, but is there a possibility that the damage is already done with the main system. I am very reluctant to fly this warbird without any kill switch being integrated to the main system due to power failure. Are there any suggestion that you may have? If this requires a repair, would that be possible?
Old 04-06-2016, 07:55 AM
raptureboy
raptureboy's Avatar
What kind of switch? Are your atv positions set to 100% on the transmitter switch? Possible mix involved?
Old 04-06-2016, 07:57 AM
dingo9882
It is the Smart fly optical kill switch that I bought with the Power system sport plus. ATV's are set to 100% and there is no mixing involved.
Old 04-06-2016, 08:09 AM
dingo9882
