Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Build a Wood Q500 Fuselage
Old 06-11-2016, 06:10 PM
sahartman21
Default Build a Wood Q500 Fuselage
Awhile back I started on some Seeker Q500 racers. The parts were cut from the laser files.
I began the process by reviewing the plans and comparing them against the cut wood pieces. There were a few changes, so I marked up the plans and identified the key components.
ID:	2167431   Click image for larger version
Old 06-11-2016, 06:17 PM
sahartman21
I modified the tray to fit a Futaba style switch.
The tray was also modified to fit a HS-225 servo (for throttle).
ID:	2167433   Click image for larger version
Old 06-11-2016, 06:23 PM
sahartman21
The parts were removed from the sheets and they were laid out.
It is generally a good idea check and see if you got all the parts. I was missing one sheet of plywood parts. One sheet did not make it to my house.
ID:	2167435   Click image for larger version
ID:	2167436   Click image for larger version
ID:	2167437   Click image for larger version
Old 06-11-2016, 06:31 PM
sahartman21
Earlier I sheeted my wings based upon this thread:
http://www.rcuniverse.com/forum/q-50...q500-wing.html
The sheeted wing, landing gear, and wood parts were used to make a kit.
Old 06-18-2016, 01:46 PM
sahartman21
Plywood doublers are attached with 3M-77 adhesive. The doublers have lightening holes. They initially covered the surface and kept the adhesive away.
Spray both sides, wait at least 30 seconds, and join surfaces.
ID:	2168540   Click image for larger version
ID:	2168541   Click image for larger version
ID:	2168542   Click image for larger version
ID:	2168543   Click image for larger version
ID:	2168544   Click image for larger version
Old 06-18-2016, 01:52 PM
sahartman21
Two pieces of wood are joined with CA to make the firewall.
The servo tray and wing attachment pieces were made similarly.
ID:	2168546   Click image for larger version
ID:	2168547   Click image for larger version
ID:	2168548   Click image for larger version
ID:	2168549   Click image for larger version
Old 06-18-2016, 01:56 PM
sahartman21
Balsa tail reinforcement pieces were glued in place.
I followed by test fitting the formers.
Each former was tacked in place with a drop of CA.
ID:	2168551   Click image for larger version
ID:	2168552   Click image for larger version
ID:	2168553   Click image for larger version
ID:	2168554   Click image for larger version
ID:	2168555   Click image for larger version
Old 06-18-2016, 02:23 PM
sahartman21
Rubber bands were used to hold the sides together until parts were glued in place.
ID:	2168564   Click image for larger version
ID:	2168565   Click image for larger version
ID:	2168566   Click image for larger version
Old 06-18-2016, 02:27 PM
sahartman21
A pencil was used to mark the screw holes.
A drill and 1/16" diameter bit was used to make the holes.
ID:	2168568   Click image for larger version
ID:	2168569   Click image for larger version
ID:	2168570   Click image for larger version
Old 06-18-2016, 02:32 PM
sahartman21
Some wood tabs were glued to the frame.
The holes location was identified and drilled.
A few servo screws holds the hatch in place.
ID:	2168572   Click image for larger version
ID:	2168573   Click image for larger version
Old 06-18-2016, 02:39 PM
sahartman21
The mount was taped in place.
The holes were drilled for the mount screws and engine kill.
The motor mount holes were drilled a second time with a 3/16" diameter drill bit.
The blind nuts were installed and pulled into the rear of the firewall.
A couple drops of CA helps to keep the blind nuts in place.
ID:	2168575   Click image for larger version
ID:	2168576   Click image for larger version
ID:	2168577   Click image for larger version
ID:	2168578   Click image for larger version
ID:	2168579   Click image for larger version
ID:	2168580   Click image for larger version
ID:	2168581   Click image for larger version
Old 06-18-2016, 02:48 PM
sahartman21
A mix of finishing epoxy and cotton flocks was made.
This mix was applied to the firewall and wing hold block joints.
ID:	2168584   Click image for larger version
ID:	2168585   Click image for larger version
Old 06-19-2016, 04:13 AM
sahartman21
The top of the fuselage was attached and the fuselage was rough sanded.
ID:	2168648   Click image for larger version
ID:	2168649   Click image for larger version
ID:	2168650   Click image for larger version
ID:	2168651   Click image for larger version
ID:	2168652   Click image for larger version
Old 06-19-2016, 02:24 PM
sahartman21
This morning a second Seeker fuselage was started. This time it only tool a few hours to rough it out.
Old 07-27-2016, 01:51 AM
Lily123
Woo,amazing!Do you have charger for Q500?
http://www.aliexpress.com/store/prod...596816313.html
Old 08-02-2016, 09:17 AM
sahartman21
If your model uses a different airfoil than provided on the fuselage, don't worry.
The pictures show how to update the sides based upon the actual airfoil.
1) Trace the airfoil on to the fuselage side.
2) Cut the sides with the tool of your choice. I used a jig saw here.
3) Build the model with the updated wing sides.
Good luck!
ID:	2175574   Click image for larger version
ID:	2175575   Click image for larger version
ID:	2175576   Click image for larger version
ID:	2175577   Click image for larger version
ID:	2175578   Click image for larger version
Old 08-03-2016, 12:49 PM
sahartman21
A few more were fabricated.
ID:	2175655   Click image for larger version
Old 08-12-2016, 06:45 AM
whiskey29
dwg or dxf for the laser cut parts would be awesome
Old 08-12-2016, 07:49 AM
sahartman21
PM sent
Old 08-12-2016, 10:11 AM
sahartman21
Here is a link to the plans:
http://quickie500.com/Plans_Seeker.aspx
Old 04-02-2017, 11:47 AM
sahartman21
The following pictures shows the alignment and attachment of the wing to the fuselage:
ID:	2208172   Click image for larger version
ID:	2208173   Click image for larger version
ID:	2208174   Click image for larger version
ID:	2208175   Click image for larger version
ID:	2208176   Click image for larger version
ID:	2208177   Click image for larger version
ID:	2208178   Click image for larger version
ID:	2208180   Click image for larger version
ID:	2208181   Click image for larger version
ID:	2208182   Click image for larger version
ID:	2208183   Click image for larger version
ID:	2208184   Click image for larger version
Old 04-02-2017, 11:49 AM
sahartman21
The process was continued until wings were attached to four fuselages.
Old 04-14-2017, 03:27 PM
sahartman21
The wood parts were glued together with Medium CA.
ID:	2209697   Click image for larger version
ID:	2209698   Click image for larger version
Old 04-14-2017, 03:31 PM
sahartman21
A slot was cut for the plywood inserts (1/64" thick) using a special tool. It consists of an Exacto blade between pieces of 1/8" thick plywood.
Inserts were shoved into the slot.
Some thin CA was used to glue the insert in place.
ID:	2209700   Click image for larger version
ID:	2209701   Click image for larger version
ID:	2209702   Click image for larger version
ID:	2209703   Click image for larger version
Old 04-15-2017, 12:24 PM
sahartman21
The tail surfaces were rough fitted with a razor plane. The final fitting was done with a sanding block.
ID:	2209945   Click image for larger version
ID:	2209946   Click image for larger version
ID:	2209947   Click image for larger version
