Great Planes US .60 help!!!!
VA
So, I got an Ultra Sport .60 from a fellow yesterday and it appears to be in great shape. It has never flown......just built, covered and then sat. I noticed that the leading edge sheeting on the left wing has come unglued from the leading edge pretty much the entire length of the left wing half. When you press on that area, you can see/feel it moving up and down. It is on the underside of the wing. Just wondering exactly how you guys might approach getting some CA in there without totally wrecking the Monocote? I figure some thin CA ought to be the easiest way but I don't know if I should try and peel the covering back (it's all Mono which is hardest to peel and redo) or poke little holes thru the covering and hit it with thin CA etc????????
Thanks for any tips/tricks you've used!!!!
1 Post
At a minimum I would remove a strip of the covering about an inch wide for the whole length of the LE and investigate the sheeting to LE joint. Easy enough to iron on a slightly wider strip to refinish things.
However if you find one botched joint that should raise alarm bells and maybe a full strip and full structural investigation is required.
.......... I noticed that the leading edge sheeting on the left wing has come unglued from the leading edge pretty much the entire length of the left wing half. When you press on that area, you can see/feel it moving up and down. It is on the underside of the wing. .....................
