Sphinx FPV racing frame - looking forward to playing in spring
let's check what this have inside!
Naze32 Acro Rev Flight Controller
Features:
- USB on right side
- PPM/PWM input as through-hole
- 3.3V, I2C on standard-size headers
- Fully pinout compatible with rev5 accessories (OSDoge etc)
- SBUS Inverter
- Spectrum satellite
- MPU6500
- Sonar pads w/resistors added for direct connection to 5V sonar
- All extra pads (FT, GP, A5) on top, only sonar on bottom
- BMP280 barometer
- 16mbit flash
32 channels 5.8G video transmitter.
NMB bearing
Leaf shaped front cap
Motor can tilt 5-10 degree to get higher speed
2pcs 5V LED decoration lights
Haha, ESCs are hiding in the carbon pipes!
Will try this out in the spring! If it gets smashed, there will be trouble to disassemble it, seems not easy to do that
Gathered some information on specs:
Wheelbase: 280mm
Flight Controller: Naze32 Acro Rev6
Speed Controller: BLHeli 20A
Brushless Motor: 2204 2300KV
Motor Tilt Angle: 5°/10°
FPV Camera: 800TVL CMOS
Camera Tilt Angle: 0°-20°
5.8G Video Transmitter: 32 Channels 25mW/200mW Selectable
RGB LED Boards: 5V DC
Propellers: 6040
Anntena: Cloverleaf Anntena
Mark: there is also a vibration-free camera mount for GoPro.
Bruce D. Pon
Wheelbase: 280mm
Propellers: 6040
Bruce D. Pon
