? On an arrma kraton shocks
This is my first rc truck,,and I'm noticing that the front end doesn't return back up when I push down on the suspension,,it seems to stay down. The rear end returns fine,,,is there a reason for this? I purchased the Kraton a year ago ( great machine) and only ran it three times. When I first got it I didn't have this problem.
THX. TAZZZZ
THX. TAZZZZ
THX. TAZZZZ
THX. TAZZZZ
Thx. Where can I get these springs,,,and what stiffness do you think is best? The front end doesn't return much at all back to level.. maybe a thicker oil. I don't know what weight oil is in these stock shocks... TAZZZZ
First, check your manual for what springs came on the shocks...AR330384 SHOCK SPRINGS: 76mm M (80.3gf/mm). Those are the medium stiffness springs.
You will want the AR330385 SHOCK SPRINGS: 76mm H (88.3gf/mm)...if you can find them. Alternate option would be to use Team Durango's TD330816 . I linked the springs @ Omni Models 'cause their prices are normally a tad bit cheaper than their sister company Tower Hobbies.
If those springs don't work for you then I guess you will have to start using rear springs to level out the front.
