Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 02-15-2017, 10:50 AM
i3dm
My Feedback: (51)
Default Introducing the Top RC Model Odyssey - New sport jet - build thread
Hello guys,
I have acquired the first Odyssey sport jet to arrive in Israel by Sky Toys.
Top RC model is a very well known company in the scale RC prop planes field, that recently started producing jets.
once i saw this jet at Jetpower 2016 in Germany, i was hooked! it is simply gorgeous and the price was hard to beat!
The quality seems up there with the best of them and so is the finish, everything seems very lightweight!
Jet comes in a variety of colors and i understand there might even be an option for custom schemes.
so, i will make a build thread about this exciting new jet and will keep you guys updated with anything i find while im at it.
The jet's specs:
Length: 2320mm/91in
Wing Span: 2190mm/86in
Turbine: 10~14kg turbine
Radio: Min. 9 ~ 11 Servos required
Description:
1. Full composite construction.
2. All surface prepainted,decals applied and clear coated
3. Scale cockpit included.
4. Detachable main wing, fuselage and tailplane & vertical fin for easy transportation;
5. Removable hatch on fuselage for easy access into the plane and change accessories;
6. Functional flaps for smooth landing.
7. High quality CNC Alu push rod included
8. More than 95% assembled complete in factory.
9. Tail tube and fuel tank included.
10. Electric landing gear with electric brakes.
i am going to be using the following gear on the jet:
- ATJ 140 SV turbine (LOVE this engine!)
- Blue Bird BLS-3507 brushless metal gear high torque servos
- Emcotec DPSI RV Mini 5 power system with redundant lipo batteries
- Cortex Pro gyro
- Futaba 18MZ for control
Some pics as it is "Out of the box". and im attaching a copy of the manufacturer manual.
Thanks to Sky Toys for making this exciting kit available locally.
Attached Thumbnails Odyssey.pdf   Click image for larger version
ID:	2201339   Click image for larger version
ID:	2201340   Click image for larger version
ID:	2201341   Click image for larger version
ID:	2201342   Click image for larger version
Old 02-15-2017, 10:51 AM
i3dm
My Feedback: (51)
This is something a lot of manufacturers overlook - packing was absolutely amazing! this is how it came out of the box!
Old 02-15-2017, 10:52 AM
i3dm
My Feedback: (51)
Some more detailed shots of the kit, untouched yet.
ID:	2201345   Click image for larger version
ID:	2201346   Click image for larger version
ID:	2201347   Click image for larger version
ID:	2201348   Click image for larger version
ID:	2201349   Click image for larger version
ID:	2201350   Click image for larger version
Old 02-15-2017, 12:59 PM
Ceeray
Looks good and pricewise beats many others.
Do you think using 220SV with reducing rpms would do fine with this one? To save money by using same turbine for several models..
Old 02-15-2017, 01:08 PM
i3dm
My Feedback: (51)
Of course its possible.
Idle thrust will be high, but thats manageable, and otherwise should be fine.
Old 02-16-2017, 12:49 AM
FMRR
Hi I3dm, I am going to follow this build thread. Can't seemed to open your thumbnails for the phots you uploaded. This jet looks a lot like Sky master Dragon, wing tips are different but even the formers look like they are in the same location. You mention the tail surfaces can be remove for transportation. On the Dragon you have to remove the thrust tube. On this jet are the removal screws external ? And are there main landing gear doors ?
Old 02-16-2017, 12:53 AM
i3dm
My Feedback: (51)
Of course.
Send me a liat of any areas you would like to get detailed pictures of, ill post anything you need.
Old 02-16-2017, 01:40 AM
GULDUKAT
Subscribed. This looks very interesting.
Can you post some images or video or the landing gear once installed and operational. The gear looks too low for this size of aircraft. Also what type and size are the tanks supplied?
Old 02-16-2017, 01:48 AM
FMRR
Originally Posted by i3dm
Hello guys,
The jet's specs:
Length: 2320mm/91in
Description:
- Smart Fly power system with redundant lipo batteries
- Cortex Pro gyro
I like to veiw the pictures you already posted . Unfortunately they are not pulling up for some reason.
Old 02-16-2017, 03:57 AM
i3dm
My Feedback: (51)
Fuel tanks are 2, made from fiberglass.
Gear doors are included, nose door prehinged and inatalled!
Landing gear definitely not too low, i will make a video of them operating soon...
Trying to attach pics again, do these work?
ID:	2201454   Click image for larger version
ID:	2201455   Click image for larger version
ID:	2201456   Click image for larger version
ID:	2201457   Click image for larger version
ID:	2201458   Click image for larger version
ID:	2201459   Click image for larger version
ID:	2201460   Click image for larger version
Old 02-16-2017, 04:26 AM
GULDUKAT
Looking nice - good images. Look forward to seeing more updates. Also let us know how this compares to the T1 Fortune jet.
Old 02-16-2017, 05:32 AM
i3dm
My Feedback: (51)
Glad to hear the pics worked this time! I will keep everyone informed of progress during the build. i am hoping for a quick build (depends on my spare time, which is not a lot).
i can already tell you its completely different from the Fortune / T1, in almost every way, different design, different size, different building technique etc.
Old 02-16-2017, 06:12 AM
FMRR
I guess I'm the only one that can't open the pictures.... all I see is a thumbnail and a paper clip...nothing happens when I try to open it.. I'm really want to see and follow this build thread.
Old 02-16-2017, 06:21 AM
i3dm
My Feedback: (51)
Please give me your email i will email you the pictures directly.
Old 02-16-2017, 08:32 AM
i3dm
My Feedback: (51)
Here's how the rudder and elevators come off.
ID:	2201496   Click image for larger version
Old 02-16-2017, 11:07 AM
i3dm
My Feedback: (51)
Here is a demo video of the electric landing gear as they came out of the box - very cool controller with Red and Green LEDs, manual button for non RC operation, and a stepped operation - impressive !!
https://www.youtube.com/watch?v=g0DhyX4R_s4
Old 02-16-2017, 12:22 PM
i3dm
My Feedback: (51)
This little guy is ready for some serious action!
ID:	2201513   Click image for larger version
ID:	2201514   Click image for larger version
Old 02-16-2017, 12:25 PM
i3dm
My Feedback: (51)
Odyssey landing gear seems VERY beefy!
Name:	odyssey LG (1).JPG
ID:	2201517   Click image for larger version
Name:	odyssey LG (2).JPG
Old 02-16-2017, 12:47 PM
leelee
Looks nice, going to have to keep up with this.
Old 02-17-2017, 01:05 PM
RC_MAN
Are you going to Toledo?
Old 02-17-2017, 02:00 PM
sysiek
My Feedback: (176)
sysiek's Avatar
The gator rc have the jets in Toledo right next to the robart booth and I think the robart is the exclusive dealer for the us .
Old 02-18-2017, 03:50 AM
FMRR
I3dm - very kind of you to go through the trouble. I saw the electric gear video that came through, still no pictures. PM your email and I will forward mine...I did not see your email in your profile...thanks .
Old 02-18-2017, 04:00 AM
i3dm
My Feedback: (51)
[email protected]
Old 02-18-2017, 04:14 AM
FMRR
Got it, just sent you email.
Old 02-18-2017, 04:44 AM
FMRR
Received your pictures, thank you. Everything looks pretty good .
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
