2x k160g2's in tail of sm f18 rpm problem
Having rpm's jump around when running the 2 engines at the same time. I'm wondering where the rpm sensor is located in relation to top (label) of the turbineon so I can seperate the sensors as far apart as possible?
My Feedback: (9)
The RPM pickup is on the right side of the engine. Leave the right engine at the normal position (kingtech logo at 12O clock) Left engine needs to be rotated looking from the rear of the engine to the left about 45 degrees. You should then do a starter test or even run one engine at a time and verify all is good.
Make sure you separate you engine wire harness for each engine.
