Eurosport Carf
Eurosport Carf
Hello friends,I am looking for my carf Eurosport a right wing.
My has got a hurt at the front edge when rolling.
Please also offer damaged.
Many Thanks, Maddin
Many Thanks, Maddin
My Feedback: (34)
Fix it. My Eurosport went down in a pile of boulders.
Several ways. But what I do in your situation. I glue a 1/4in round carbon fiber Dow in the front leading edge. This needs to connect past the damage on both sides to keep leading edge straight.
Next step is up to you. Get a balsa block, and to shape to fill gap, strip paint /body 1/2in around all damage, then fiberglass 1 layer of 4-8oz (cheap stuff at hardware store). Use the thick glass to make sure you like your leading edge. Then one supper thin 1/2oz cloth to tie it all together, block sand, primer. You can take the wing to an auto paint store to get matching paint or time to go different
easyer way same as above, but cover all missing parts with clear packing tap, then spray the leading edge with can spray foam from hardware store. Be careful not to let it budge your good part off wing. It's ok if the foam excapes out of the dame area. Make sure to use epoxy finishing resent as it is what the wing is made of. Z proxy will work great. Good luck
