transmitter or receiver problems
I have an ar9020 receiver in it I was do a fast level fly by and all of a sudden she went into a loop with no transmitter input so I land and do a range check looked everything over everything is working fine so I take off start a slight right bank and then the plane banks left and right really quick back n forth about 4 times and then stops so I land and still cannot find any problems its like I'm getting random signals to or from the receiver. anyone have any ideas or have this problem
its in a 90-1.20 size mxs-r 30cc gas engine 3s lipo into a 6v bec to the receiver and a second 3s lipo for ingnition. a rcexl ignition kill switch futaba 3010 servos a futaba 3004 for throttle, one eflite micro servo for the choke ar9020 high speed sport receiver with 2 satellites
sorry I'm not great at explaining things I never actually loose connection or loose control of the model I'm trying to find the right words to explain lets say its like a hiccup for a sec the plane will twitch almost like someone came up and flicked one of the transmitter sticks it will aileron twitch or elevator its all random now I say twitch but its enough to put the plane on it side or straight nose up its just for like less then a sec cause I have full control right away but I'm guessing its only a matter of time before it decides to do it nose down while I'm trying to land. I put the receiver in one of my electric foamies today and had 4 perfect flights no problem
