CARF Mephisto Build thread
Old 08-18-2017, 05:05 AM
Dave Wilshere
Default CARF Mephisto Build thread
CARF Mephisto production is now in full swing, there have been three prototypes doing the test flying. I have one of the pre production kits to assemble, so this is the start (timing is bad as I have a jet meeting this weekend and then 3 days with my family so progress won't really start for another week.
The model has so many design features it needs a brief intro.
CARF decided that this design needed a fully ducted install, which is much more expensive to produce, but gives a better flying aeroplane at this size (less drag when you power off) It also needed enough fuel for the expected 220-300 turbines, though it would fly on a 180 no problem.
The overall fuselage length at 3.1m 122" wouldn't fit many cars and most vans easily, so the fuselage splits at the wing trailing edge with just three cap head screws.
The really neat thing is the three piece wing and gear all mounted in the front section. This is 86" long and 30" wide.
The gear is designed to have all three wheels below the fuselage when retracted so you can roll the section around on a flat bed. Gear is specially designed by Electron for CARF.
I have the green scheme and its going to have a JetCat P-220Rxi-B. JR 8911, 8931NX servos on the main controls and 3 x JR 579/ST126 on the gear doors.Support will be Powerbox, a MAP Hi-Flow bubble trap and a JR 28X.
Few pics to start with.
ID:	2228404   Click image for larger version
ID:	2228405   Click image for larger version
ID:	2228406   Click image for larger version
ID:	2228407   Click image for larger version
ID:	2228408   Click image for larger version
ID:	2228409   Click image for larger version
ID:	2228410   Click image for larger version
ID:	2228412   Click image for larger version
ID:	2228413   Click image for larger version
ID:	2228414   Click image for larger version
ID:	2228415   Click image for larger version
ID:	2228416   Click image for larger version
ID:	2228417   Click image for larger version
ID:	2228418   Click image for larger version
ID:	2228420   Click image for larger version
ID:	2228421   Click image for larger version
Old 08-18-2017, 06:30 AM
skymaster68
Great Dave, I also have one coming this way !!!
Old 08-18-2017, 07:39 PM
felker14
My Feedback: (50)
felker14's Avatar
Thank you Dave for doing this build thread. Your threads on Comp-ARF models are great source of information.
Old 08-19-2017, 09:08 AM
Dave Wilshere
Thank you, this is a surprisingly straight forward build on production models, all the fiddly parts will be done, even the screen will be factory fitted.
The guys in Germany, put one together in 3 days with a couple of guys working on it.
im looking forward to getting back from this trip and cracking on with it.
Old 08-28-2017, 09:50 AM
Dave Wilshere
OK, back from family break and our National championships, so got the Mephisto out again. Looking at the wings. Put a mag on there to show you the size!
Old 09-03-2017, 03:54 AM
Dave Wilshere
The flaps are huge, the plug in outer wing and flap works really well. I hope to have a run at this over the next few days.
ID:	2230326   Click image for larger version
Old 09-04-2017, 03:32 PM
sailing1
My Feedback: (134)
Dave, do you know if there will be an option for electric gear other than Electron? I have nothing against Electron gear but already have 4 planes with Behotec Electric gear and wonder if it wouldn't make sense to stay with what I know and like just for uniformity of programing and spares.
Old 09-04-2017, 09:13 PM
Dave Wilshere
No, only Electron. The Behotec gear won't fit and the Electron gear is custom produced just for this aeroplane. The forward retracting gear and proud wheel requires mechanical support to avoid damage to the actuators.
Ive not been a fan of electric gear, but the operation of these units is very reassuring.
Dave
Old 09-04-2017, 09:30 PM
dubd
dubd's Avatar
I love the thoughtfulness of the design of this plane. Dave, Looking forward to hearing your flight report.
Old 09-04-2017, 10:50 PM
Dave Wilshere
There is so much. The production flap set up works really well. I'm using JR 8931NX servos with a short arm. The flap just plugs in before the outer panel is fitted. Current is 100-200mAh throughout the range unloaded. Putting a flight load on the flap with it in full flap position is only reads 0.8-0.9A! The geometry Andreas had come up with takes the load off the servo.
ID:	2230606   Click image for larger version
ID:	2230607   Click image for larger version
ID:	2230608   Click image for larger version
ID:	2230609   Click image for larger version
Old 12-02-2017, 10:53 AM
Dave Wilshere
I’m very close to finally finishing mine, but Steve Johnson’s example was ready, so I have been up to his field and we test flew it today. Because of an oversight no one had a camera at the field so we will have to wait for flight shots. Steve’s has a KT310 for max power, low cloud stopped that being tested to the max, but what a machine. Even without a gyro it’s the most locked in model I have flown in a long time. No mixing and the knife edge tracked horizon to horizon, 10 mm of rudder!
slow flight is super solid, huge flaps slow it down. Steve stripped it at the end of the day and it’s less than 5 mins and fits in a std station wagon/estate car.
ID:	2246691   Click image for larger version
ID:	2246692   Click image for larger version
ID:	2246693   Click image for larger version
Old 12-02-2017, 11:44 AM
JP-1
Looks very good D, its huge isnt it?
Is that Ramsey? just looking at the mast?
Old 12-02-2017, 11:58 AM
Dave Wilshere
AP
Yes, huge, but pulls down to small parts, so would even fit your VW!
Yes, Ramsey club field.
Old 12-04-2017, 05:57 AM
skymaster68
Old 12-04-2017, 12:13 PM
Dave Wilshere
Markus has been playing with set ups and experimenting. So much seems to be
Old 12-07-2017, 12:51 AM
Dave Wilshere
Another scheme option.
Old 12-07-2017, 03:13 AM
skymaster68
That looks familiar, it’s coming my way 😛😛
Old 12-07-2017, 03:35 AM
Dave Wilshere
Old 12-09-2017, 07:58 AM
ZivBit
ZivBit's Avatar
Hi Guys
We bought 2 Mephistos with custom schemes.. Played a little with the color swaps and this is what turned out..
Black-orange-silver-gray.
Thanks to Andreas and his team for the patience and responsiveness.
Cant wait to get it in few weeks time..
Ziv
ID:	2247271   Click image for larger version
ID:	2247272   Click image for larger version
ID:	2247273   Click image for larger version
ID:	2247274   Click image for larger version
Old 12-09-2017, 08:00 AM
ZivBit
ZivBit's Avatar
And the second one for my buddy Naor:
Black-Red-Silver-Gray
Cheers,
Ziv
ID:	2247276   Click image for larger version
ID:	2247277   Click image for larger version
ID:	2247278   Click image for larger version
ID:	2247279   Click image for larger version
Old 12-09-2017, 11:09 AM
Dave Wilshere
Nice! really like both of those.
Old 12-10-2017, 03:51 AM
Andrew Bird
Andrew Bird's Avatar
Yea - they are great. It's growing on me more and more as I see more great scheme choices.
Old 12-23-2017, 09:10 AM
Dave Wilshere
Well finally got a chance to fly my Mephisto. Not really the best conditions, low cloud, quite dark and damp-but its such a sweety. Take off roll is around 40-45m and landing today with a 10mph head wind around 25m! Touch down on each of three flights only used 60m of the whole strip.
First flight with no gyro showed it does not really need one! No couple in KE and really solid all around. Second flight was to dial in the Royal SRS iGyro and third to test and tweek expo and travel in each mode.
A club member whose kit is on the way came to watch and he was very happy. Couldn't have gone much better as far as test flying goes. With the low cloud limiting vertical stuff 7 minutes only used just over half the tanks, vector and power will reduce that, hoping for better weather next time I can fly.
ID:	2248464   Click image for larger version
ID:	2248465   Click image for larger version
ID:	2248466   Click image for larger version
ID:	2248467   Click image for larger version
ID:	2248468   Click image for larger version
ID:	2248469   Click image for larger version
ID:	2248470   Click image for larger version
ID:	2248472   Click image for larger version
ID:	2248473   Click image for larger version
ID:	2248474   Click image for larger version
ID:	2248475   Click image for larger version
ID:	2248476   Click image for larger version
ID:	2248477   Click image for larger version
ID:	2248478   Click image for larger version
ID:	2248480   Click image for larger version
ID:	2248481   Click image for larger version
ID:	2248482   Click image for larger version
ID:	2248483   Click image for larger version
ID:	2248484   Click image for larger version
ID:	2248485   Click image for larger version
ID:	2248486   Click image for larger version
Old 12-23-2017, 03:33 PM
JP-1
Will we see it at C.J. D?
Old 12-24-2017, 01:41 AM
Dave Wilshere
A
That’s the plan, hope to get a chance to do a little more setting up on it. Not played with the Vector yet and there is gyro fine tuning to get the very best from each mode.
D
