what is 3D Flying
jnayjaso (04-05-2020)
Not trolling at all. How much "flying" is done in 3-D? Everything I've watched is a big engine pulling around a body. Watch some real competition flying like Red Bull - they do real flying.
"3D Flying" encompasses a large variety of flight, it's best just to show you an example:
Much skill is required to make the aircraft fly as smoothly as Kyle does, it's not something someone picks up in a couple days of practice.
The following 2 users liked this post by Xpress:
jnayjaso (04-05-2020),
mithrandir (02-26-2021)
You think it's easy? You want REAL flying? Next time you're out flying, here a challenge for you, exercising a basic 3D skill. While coming in for a landing, add some power and up elevator, and hold your plane off the runway about 18" or so, the length of the runway. Then do a rudder turn and come back..... all without increasing your speed above landing speed, and never gaining more than 4' of altitude. With proper set up (yes, you get to figure that out too!), about any decent sport plane should be able to do that. Then come back and tell us 3D is all "big engine pulling around a body".
As a full scale pilot, I have terrific admiration for the way those guys handle those Red Bull planes (like flying back to an airport after dipping a wing tip in the Detroit River), and even more for the advances made in their construction. The power to weight ratios they get to play with, well the more you know about them, the more amazed you become. That said, I don't consider what they spend most of their time doing 3D flying, not the way I think of 3D anyway. -Al
Rafael
Hope you're well, I've been playing with more jets and 3D airplanes (not flying them, just dragging them around with a big motor) than heli stuff lately.
I assume Irma left you alone?
Rafael
![Smile](images/icons/icon7.gif)
I view 3D flying as way to show off skill with the transmitter. I'm not that skilled and, as a consequence, I get bored watching 3D flights. My skill level allows me to fly for fun and have a ball doing so. I consider that equivalent to the 3D flyer.
Ask a 3D-Champion to perform a slow roll using the whole runway.....
The goal is the combo with 3D Flying an precise dynamic flying.
Andrew Jesky for example is a pilot who has all the skills for both types of flying!
Banned
Lets keep it simple for a first lesson. The engine/propellor/turbine overcomes the drag to pull the plane forward through the thrust it creates. Now imagine a cross section of a wing. Flat across the bottom and curved across the top. Point A is the middle of the forward edge of the wing, and the rear edge is point B. The distance across the top of the wing from A to B is longer than the bottom flat wing from A to B. Now imagine two molecules of air hitting the front of the wing. One molecule goes across the top, and the other across the bottom. The top one has to travel a greater distance, but it MUST meet the other molecule at the rear edge of the wing. To meet the bottom one, the top one must go faster. This creates an area of decreased pressure on the top of the wing, and increased pressure on the bottom of the wing, which creates LIFT. The engnine must pull those wings through the air fast enough so that enough lift is created to raise the plane above the ground. Each plane has its own statistics as to when it can fly. A microlight might be able to take off at 30mph, a large jet may reach 130mph before it begins to have enough lift to raise all that weight.
So how do you account for a plane that can accelerate out of a Hover? Clearly that's not requiring a lot of lift from the wing. Or a roller, where the plane is rolling on it's axis with a forward speed of a walking pace?
3D is about a plane in motion that's defying most of the rules of flight that we've observed previously or been taught. That's one of the reasons it leaves people with the thought that planes can't do that - when clearly, they are looking at one that proves that thought incorrect....
3D flying is all about fun and skills at work. More of it today between the heavy showers with my 10 YO giant Depron one, no sign of wear after all these years!
(Giant 3D Depron flight)
A common sense pilot never blocks any one from flying, just enjoy his or her skills.
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/851x637/drying_out_the_field_after_storm_a2e4f4e75df53b82d4dc4f8ff8692de73c50c447.jpg)
Drying out my flying field after he storm.
The most basic rule flying any model at the MAAA Club is to stand in the pilots box, so there's no way you can block anyone else flying standing on the runway! Plus, it is a basic courtesy not to do 3D manouvers in front of pilots box when other pilots fly their regular pattern. It is just a common sense, and if you don't observe these basic rules the Club's safety officer should tell you to p/off.
https://youtu.be/LJOffAcGGls
if you set the playback speed to 2 it looks like 2021 full throttle 3D!!
![Stick Out Tongue](images/smilies/tongue.gif)
