hanger 9 80'' cap232
Old 09-26-2003, 06:32 PM
flybabyg38
My Feedback: (18)
Default hanger 9 80'' cap232
would g-38 work with this it is 3oz lighter than g-45, but won't swing 20'' prop very well. Mine swings 18-6-10 at 79 to 8,000 rpm's. might try to move batt back further into plane and not add any lead to tail. Would like to try to use engine i all ready have.
Old 09-26-2003, 10:19 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Default RE: hanger 9 80'' cap232
If you are not into the vertical stuff....a G-38 will be O.K....not great, just o.K.
Jerry
Old 09-26-2003, 11:24 PM
Mike Rojas
Mike Rojas's Avatar
IMO,either of those Zenoahs is the wrong engine for that plane.This plane already comes in heavy with a DA 50 or BME.The Zenoahs will make it even worse,and they are not that powerful to boot.Like I said JMO.We had one with a DA 50 and friend has one with a Brison 3.2 and they were both over 16 lbs,and we didn't do anything ridiculous like super large batteries or anything like that,pretty much all standard building technique.
Mike
Old 09-29-2003, 11:19 PM
vkmaynard
How would it fly with a ZDZ 50?
Victor
Old 09-30-2003, 12:18 AM
azhar
My Feedback: (19)
Very well.
Azhar
Old 09-30-2003, 10:04 AM
fishgod
My Feedback: (13)
fishgod's Avatar
I have one with a Taurus 52. Below are my stats.
Taurus 52 w/ Mezjlik 22x10, Dave Brown Spinner
1650 on ignition, 2700 on reciever
5@ JR 8411 on control surfaces
2@ JR 811 1 one throttle 1 on kill switch
JR Prolinks with Rocket City 8-32 control horns/ball links
24 oz fuel tank.
Now I am at 15.7lbs. If I wanted to spend a bit of money I could get it in the high 14's or very, very low 15's. The plane is awesome. Keep the throws low and the CG forward and the plane tracks extremly well. Move the CG back, increase the throws you will end up with a 3D tumbling monster. I would not go with anything less then a 50. I had a ZDZ40 in it and it was just not enough for Sportsman/Intermediate IMAC. The 40 was strong and great for sport flying but just didnt have the oomph for IMAC or 3D. Hope this helps
Old 09-30-2003, 10:37 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
Buddy is putting one together with a Taurus 52 also. Hope to see it go this weekend!
Old 09-30-2003, 11:27 AM
fishgod
My Feedback: (13)
fishgod's Avatar
JohnVH,
I am really impressed with the Taurus. It is a extremly smooth running motor. I have about 3 gallons through it now and It is really comming on strong. I can take off pull it straight vertical do 2 aileron rolls then a double snap and keep on going. With the CG towards the back the plane pitched hard to the belly and rolled slightly in knife edge. I have moved the CG forward for sequence flying and the pitching is not near as bad. point rolls and knife edge are very easy now and they look darn pretty.
Old 09-30-2003, 11:32 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
good to hear! We will have some vids of it up once its going.
Old 10-01-2003, 09:18 AM
s3nfo
My Feedback: (14)
G45 on mine at just a hair over 17 1/2 lbs. G45 is more than enough for sport flying, not enough for 3D, but then neither am I.
Old 10-01-2003, 09:37 AM
rmh
rmh's Avatar
this is a great looking model but very easy to make tailheavy -and then - just plain ol heavy once it is balanced -
ideally -it is under 15 lbs - but in real world -17 lbs comes up .
if you really want top performance - then make the tail group as light as possible - re do it if necessary - the model is not expensive and this fix is well worth it .
if you can pull 4 ounces out of the rear - it results in over a lb less needed up front .
big improvement.
I have flown the Caps -from Midwest (basis for this model as well as scratch built clones of this and -a H9 one with a ZDZ50 NG.
the H9 is 17.25 lbs -balanced by the owner -
power is nooo problem but the power off or low speed performance really is different -compared with 14-15 lb clones .
Old 10-01-2003, 11:16 AM
epc
My Feedback: (33)
epc's Avatar
Well i have not weighted mine but it flights extremely well and feels light with a zdz 60 and 24x8 menz s.
epc.
Old 10-01-2003, 02:49 PM
flybabyg38
My Feedback: (18)
Thanks for all the help made offer on bme 50 and have talked to Bill at taurus about a 3.2 i think that is the ts52. Would somebody give me the control setting in something other than degrees. and what did you set up on your C-G. Thanks Tim
Old 10-01-2003, 04:08 PM
SunShyne
My Feedback: (68)
SunShyne's Avatar
guys, there is one collecting dust at my lhs and I was considering one. Do you think the Moki 2.10 would work on it?
Old 10-01-2003, 04:54 PM
fishgod
My Feedback: (13)
fishgod's Avatar
flybabyg38,
I have found that you want to start at the front of the CG range. Whey I first flew the plane I set the CG just about in the middle of the range or a smidge past middle. When coming in for a landing the nose would ballon up. It never snapped on me but it just didnt give me a warm fuzzy feeling. So I moved it forward and the balloning stopped. When inverted I have to put a touch of down elevator to keep it level. Also keep your low rate elevator around 5/8 of an inch. Rudder I have all you can get and I like quick ailerons so my low rate is somewhere around 1 to 1 1/4 inches. The elevator throw does not sound like much but it is more then enough for sequence flying.
Old 10-02-2003, 10:10 PM
epc
My Feedback: (33)
epc's Avatar
Ok guys just weighted mine and now I understand why it feels so light and powerful:
15lbs 10oz w/ ZDZ 60 and Menz 24x8.
epc.
Old 10-02-2003, 10:16 PM
Warren
My Feedback: (72)
Warren's Avatar
My H9 Cap with the DA50 and Slimline Pitts is 15 pounds 7 ounces...
All stock and weighed on two scales.
They aren't that heavy in my opinion.
Old 10-03-2003, 05:08 AM
Flyin Woodbutcher
Hey yall stop your bragging about the weight . Mine weighs16lb 12 ozs with a 3W 50. Beat that if you can hahahaha. Plane flies great and lands slow and lite. Vertical is unlimited.
Kent
