The ULTIMATE Model Kit--Ultimate Jets A-12 Oxcart Project!
Old 03-06-2018, 04:17 PM
Shaun Evans
Shaun Evans's Avatar
Default The ULTIMATE Model Kit--Ultimate Jets A-12 Oxcart Project!
Hello,
I am about to start construction on what I think is the most impressive model kit I've ever had in my hands--and by far the largest! In this day of huge jet models, we've become used to great, big models. This one, though, was a jaw-dropper for me.
I think you'll all be impressed with the quality of the layup, engineering, fit and finish of this kit. The thing you just can't get a sense of unless you touch it is the weight, though. I'll discuss that more later with measurements. My 12-year-old son can pick up the nose section (roughly 6' long with the scale nose unit installed) with only two thumbs and two forefingers
I'm still gathering the components (electronics and engines), but will start on the construction this week. In preparation for this, I've been doing a lot of reading on the history and heritage of the A-12, and learned that the specimen sitting at the San Diego Aerospace Museum a few miles from me has flown higher and faster (and in real-world hostile missions) than almost every other man-made airplane to take flight. I'm sure I'll be visiting that full-scale A-12 a few times before I'm done.
Regarding the pics, the first two are factory shots. The last one is the plane sitting in my spare bedroom. For reference, that room is 15'x18'
Feel free to chime in and enjoy this build with me!
ID:	2257911   Click image for larger version
ID:	2257912   Click image for larger version
Old 03-06-2018, 04:24 PM
SECRET AGENT
My Feedback: (18)
SECRET AGENT's Avatar
Glad to see you have your priorities in order with your spare bedroom, HA!! I can certainly relate!
Looking forward to this one.
Old 03-06-2018, 06:17 PM
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
I am following this one. Please post lots of photos. Good luck. Keep us posted.
Gary
Old 03-07-2018, 01:53 AM
raron455
My Feedback: (38)
raron455's Avatar
droolin over here,,,,,
Old 03-07-2018, 06:04 AM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Be good to your wife....If she gets mad at you and threatens to shove that one you are in for serious problems! Great choice for picking you as the builder....now as Larry has to say....."Getter dun!"
Old 03-07-2018, 06:27 AM
Pantherman
Pantherman's Avatar
Looking forward to seeing your skills on this one Shaun! Keep us posted as you progress.
Woody
Ultimate Jets
Old 03-07-2018, 01:18 PM
ravill
ravill's Avatar
Shaun, post better pics man!!!
Don't tease like that!!!
Old 03-07-2018, 01:25 PM
Shaun Evans
Hehe,
No kidding, right?? Some will go up later tonight
Old 03-09-2018, 04:27 AM
Shaun Evans
Hello,
Here are a few better pics. 1. The first pic shows the fuel cells in their compartment. The cells are kevlar with some very nice caps, cap fittings and plumbing. I'll go into that in more depth later as I get them plumbed and installed. 2. This is a shot of the nose gear mount bulkhead. The gear are mounted to carbon flex-plates which are bolted to rigid mounts. 3. The nose gear unit gives an excellent canvas for the 'hyper-scale' type modeler, and I plan to really spend some time channeling my inner Paul Reese on these. 4. The molded detail of the 'corrugated' skin on the bird is evident here. 5. The left main gear unit. Again, the scale detail is astonishing. These struts are integrated into a Behotec pneumatic unit. Each wheel has its own pneumatic brake. These are also offered in electric, but I have always preferred pneumatic. 6. The engineers on the Archangel and Oxcart projects developed lots of ways to make all of this work in previously unknown or unchallenged flight environments, and these leading-edge triangular 'chines' were part of solving several problems. They're molded in, too. 7. The nose/fuse joint seen through the main hatch. There are carbon tubes inlaid perpendicular around the bulkheads, and carbon pins slide into those to brace the two parts. Then bolts seal the deal. 8. The right engine compartment with the hatch removed. You can also see the rear end of the intake cone. These engine mounts mate to custom bypass/pipe combos that are tailored to whatever engine you choose.
You can't appreciate the feather-light weight of the components through pictures, so I'll take some shots of some of these parts on a scale.
ID:	2258602   Click image for larger version
ID:	2258603   Click image for larger version
ID:	2258604   Click image for larger version
ID:	2258605   Click image for larger version
ID:	2258606   Click image for larger version
ID:	2258607   Click image for larger version
ID:	2258608   Click image for larger version
Old 03-09-2018, 05:36 AM
Halcyon66
Good looking airframe.
Regards,
Old 03-17-2018, 09:39 AM
Shaun Evans
Regards,
Hi,
I'm still grinning and scratching my head at the same time about how light and yet strong this airframe is.
Old 03-17-2018, 10:11 AM
Shaun Evans
MKS servos
Pretty robust metal arms!
Two of these MKS servos will be ganged together on the outboard ailevators.
ELECTRONICS
So for the first consideration to tackle on this build, I had to narrow down which electronics I would be using. I'm still on the fence regarding receivers, but I've selected the servos. I posted a while ago on another thread asking for peoples' input and experiences with different servo brands. When I first got into jets, JR electronics were all the rage. I'd been pretty happy with them over the years, but recently I've had several 8611's and 8711's be on the fritz right out of the box. In fairness, they'd been sitting for a long time, but never out of the box. With JR and Horizon calling it quits, I felt like I was left holding the bag on several really expensive servos so I went on the hunt for something new to try. I've had so-so luck with Hitec, so I took a look at a few brands like Savox, Spektrum and Align. They have some nice offerings, but Doug Cronkhite turned me onto MKS. I'm currently building an F-18 Twin for a fellow here in San Diego, and we ordered some for him. If you haven't seen or used these servos, they're pretty impressive! I talked to Thomas at MKS, and he was happy to spend a lot of time on the phone with me about what would suit my project best. I decided to go with their X6 series HBL 599 standar-sized servos. They have titanium-chrome allow gears, brushless motors and an operating voltage range of 3.5 to 8.4 volts. At roughly 500 inch-ounces of torque at 6.6 volts, they're pretty strong. I watched some Youtube of these servos in action on some pretty large aerobats with pretty large control surfaces slamming back and forth and was convinced.
The metal arms I ordered looked WAY smaller on their web-page. These things are the textbook definition of 'overkill', but that's what I want on a bird like this. I drilled and tapped them out for the 4mm studs that come with the hardware pack for this airplane and have the full-flying vertical stabs and the outboard ailevators connected.
Old 04-10-2018, 06:40 AM
enaltoe
Originally Posted by Shaun Evans
Hello,
Hello Shaun,
a great model!
I have almost completed the SR 71. The only change I have made is to strengthen the landing gear fixing plate.
Ciao.
Enry
ITALY
Old 09-08-2018, 07:05 PM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Default Updates?
Hi guys
Any update on either of these builds?
Considering getting one of these.
‘Thanks
Old 09-11-2018, 09:35 AM
guido123
Great model
Old 03-15-2019, 03:37 PM
YellowAircraft
Hi,
I've restarted my project, but am waiting to get rid of this "Yellow Aircraft" account and recover my "Shaun Evans" one before I start posting on it. She's gonna fly this season!
Old 03-15-2019, 03:56 PM
YellowAircraft
Error...
Old 03-15-2019, 03:58 PM
YellowAircraft
Hi,
While I'm waiting for RCU to help with the account thing, here's a preview pic. I can talk all day about how light this layup is, given its considerable strength and rigidity, but a picture is worth a thousand words they say. This is my 6-year-old daughter holding up the nose section. It's about 6' x 17", and has the big Behotec nose unit installed already. She's not on steroids or from Wakanda, either!
Old 03-16-2019, 12:39 PM
olnico
olnico's Avatar
Glad to see that the little class is takmg over..
She looks like she could be from Wakanda, though!
Old 03-17-2019, 03:04 AM
YellowAircraft
Hi,
Yeah, she's a cutie, right? She LOVES 'helping' her Papa in the shop, too.
Old 03-17-2019, 03:30 AM
olnico
olnico's Avatar
Originally Posted by YellowAircraft
Hi,
Nice! Enjoy that until she becomes an ado and be more interrested in partying than anything else.
Ask me how I know this...
Old 03-17-2019, 05:44 AM
YellowAircraft
Oh,
I'm sure. My 13-year-old used to be joined at my hip whenever it came to anything flight-related. My RC-buddy, my Cessna-buddy. He turns 14 next month, but last month he noticed girls. Suddenly he's busy texting girls and has less time to fly...
As for this little one, it seems she was in diapers yesterday. Now, she just saw this pic and wants me to point out she's holding that nose section with one hand.
Old 03-17-2019, 10:27 AM
FenderBean
FenderBean's Avatar
I would love to own the SR-71 version someday and do a movie scheme on it. Its one of those jets that doesnt need to do flashy stuff to enjoy flying it!
Old 03-18-2019, 03:45 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
I love the fact that it is an A-12 and not an SR-71.
Something about being a Skunkworks whimp!
Old 09-02-2024, 02:45 PM
Flite-Metal
Flite-Metal's Avatar
Shaun,
Did you ever get the 12 completed? This thread simply ended incomplete...
Ed
