Go Back  RCU Forums > Marketplace
Tempest 600 EP RTF Aircraft electric
Old 03-24-2018, 06:14 AM
Ibcinyou!
My Feedback: (850)
Ibcinyou!'s Avatar
Default Tempest 600 EP RTF Aircraft electric
The Tempest 600 EP is a great airplane for someone who either wants to get started in RC flight or an enthusiast who's looking for a relaxing, fun airplane to fly. It comes complete as a RTF, so everything you need is in the box (including a 2nd battery). The airframe is made from durable EPO foam and the pusher-style design and optional blade guard provide added safety. The Tempest also includes a lightweight 4-in-1 RX/ESC combo with two integrated 1.3-gram servos for control. Plus, the PASS (Pilot Assist Stability Software) provides novice pilots with 3 options for flight control as they learn to fly: Full Assist, Partial Assist, or No Assist (system off). These levels can be conveniently controlled from the transmitter during flight.
Key Features:
Made from durable and easy-to-repair EPP foam
Pusher-type design results in fewer broken props due to rough landings
Included optional blade guard provides extra safety for younger pilots
600mm wingspan allows for easy transportation
4-in-1 Control System with two integrated 1.3-gram servos
Coreless direct-drive motor delivers outstanding thrust and extended flight times
2.4GHz transmitter provides interference-free link between pilot and aircraft
Includes two 1S 3.7v 300mAh Lipo batteries for extra flying time
PASS (Pilot Assist Stability Software) system provides confidence as skills progress
With PASS, a simple transmitter-mounted switch allows pilots to easily choose from three levels of system engagement: Full Assist, Partial Assist, and No Assist.
Specifications:
Wingspan: 23 5/8" (600mm)
Length: 18 1/8" (460mm)
Weight with Batt: 2 1/8 oz. (60g)
Battery: 1S 3.7v 300mAh Lipo (2 included)
Transmitter: 4-channel 2.4GHz
On-Board-Electronics: 4-in-1 Control System with two integrated 1.3-gram servos
Flight Controls: Rudder, Elevator, Throttle
Items required for completion: 4 AA batteries for transmitter
Ibcinyou! is offline
