Power Box Champion (40/24) w/ Smart Switch
My Feedback: (31)
Max. Constant Current: 2 x 20 Amps Input / Output Channels: 7Servo Pulse Amplifiers: 7Servo Matching Control: 3 Channels Servo Connections: 24Temperature Range: 14° F to 131° FPower Supply: (2x) 5 Cell
NiCd or NiMh Packs
or Lithium Ion / Polymer
7.4V to 11.1V
Working Voltage: 6.0 V to 11.1 VCurrent Drain: 130 mA Voltage Loss: 0.2 V Weight: 5.4 oz. incl. switchSize: 3.66" x 2.91" x 0.75"
NiCd or NiMh Packs
7.4V to 11.1V
- Servo Matching Control on
THREE Channels - Double linear regulation for
servos & receiver/s - Voltage to servos & receiver/s
regulated to 6V - Electronic 2-way security switch included
(no more accidental shut-off / turn-on) - Both Batteries Separately Switchable
- Low voltage / in-flight error memory
(status LED's and telltale button
report any in-flight conditions) - 2 independent voltage controllers
- 2 bright external status LEDs
- 2 Internal Voltage Bar Graphs
- Triple redundancy power connectors
(3 common + and - pins in each connector) - Ideal soution to suppress
jet electronic noise - Perfect for dual receiver installations
