Unique Custom Built Jeep Grand Cherokee WK Scale Rock Crawler Free Shipping!
My Feedback: (28)
Unique Custom Built Jeep Grand Cherokee WK Scale Rock Crawler.
Very Rare and hard to find Jeep Grand Cherokee Hardbody.
There are over $850.00 just in new parts to build this truck and that doesn't include any labor which there was quite a bit of to build this rig.
New Customized Axial SCX10 4-Link Chassis shortened on both ends.
Yellow Cad Scale Miniature Hex Head Bolts on chassis assembly.
New RC4WD Rare, Discontinued, T-Rex 44 Mini Front and Rear Axles upgraded with Scale Miniature Hex Head Bolts.
New RC4WD 4 Link Mounts for T-Rex 44 Mini Axles, Front and Rear.
New Aluminum 4-Links, front and rear.
New Aluminum Steering Links.
New Axial SCX10 Transmission including new style Steel Outdrive Shaft Set, Slipper Clutch, Pinion Gear, Spur Gear and cover.
New RC4WD Mega Truck Scale Steel Driveshafts.
New RC4WD Scale 80mm white Shocks with Internal springs, upgraded with soft spring set.
New Gear Head RC 1.55 Slot Mag Wheels.
New Locked Up RC M2 Acorn Wheel Studs.
New RC4WD Mud Thrashers 1.55 Scale Tires
Hidden Velcro Body Mount System.
Steering servo mount pre-installed including servo mounting screws.
Just add electronics and go! Steering servo, ESC, motor, battery and radio equipment Not Included.
The wheel wells are left unmodified in case you go with smaller tires for a "stock" appearance, otherwise you can contour them for clearance to suit your taste.
I listed this item as new since the entire chassis and drive train are new. The Jeep body itself is of course used, in good condition.
FREE SHIPPING!
Tags: Axial scx10 scx-10 scx Dingo Honcho Cherokee scaler 1/10 scale 4WD RC rock crawler rock Crawler truck car RC4WD Tekin motor rpp hobby junfac vanquish proline Pro-line masher hot racing rccrawler tsccrawler tsc 3racing twenty1eleven rcsparks wraith xr10 sx Radio Electric Control Nitro gears Savage Baja Team Race Cars 2.2 1.9 1.55 clodbuster clod mud-slingers stamped steel wheels tamiya tires wheels bead locks bead lock radio control lipo mud thrashers
FREE SHIPPING!
