Go Back  RCU Forums > Marketplace
JP Hobby High Thrust 90mm EDF with 1750KV 6S Motor JPHEDF09006S
Old 05-04-2018, 10:03 AM
jdcarman
Default JP Hobby High Thrust 90mm EDF with 1750KV 6S Motor JPHEDF09006S
Up for sale is the JP Hobby High Thrust 90mm EDF with 1750KV 6S Motor JPHEDF09006S. I got this from a friend and he bought it new. Comes with connectors fro the ESC.
Specifications:
- Rotor Blade Material : High Grade Aluminum Alloy
- Outer Diameter: 93mm
- Length: 74mm
- Weight: 485g ( Whole Unit )
- Connector: 5.0mm Banana
- Rotor: 90mm , 12 Blade Normal
- Motor:: JP Hobby 4250 12 Pole 1750Kv Outrunner Motor (Installed)
- ESC: 120A - 150A Brushless ESC With 15° Timing (Not Include)
- Working Voltage: 6S 22.2v
- Average Thrust: 3.47kg At 22.2v ( 103A ) , 4.01kg At 24.0v ( 117A )
- Max Thrust: 4.32Kg At 25.2v ( 126A )
Buyer pays shipping. If using PP use friends and family or add 3% if using the business method. Comes as is.
jdcarman is offline
