Harlock RC Viper 140
Old 08-28-2018, 06:01 PM
F1 Rocket
Default Harlock RC Viper 140
Just finished and shipped this very cool little Viper Jet from Harlock RC. These are available from Jag RC here in the USA.
Jets Munt Merlin 70
bavarianDEMON Cortex Pro
Jeti REX 12
Jeti MSpeed
Jeti MUI 30
MKS HV69 (flaps, nose wheel) HV93 (ail, elev, rud)
Xicoy ECU telemetry
Intairco Mini UAT
Electron ER-30
Danny
Old 08-29-2018, 05:50 AM
LA jetguy
LA jetguy's Avatar
Thanks a lot Danny and the team at the “Rocket Factory” ... Can’t wait to fly it over the Labor Day weekend. Will post after maiden...
David
Old 08-29-2018, 05:59 AM
BarracudaHockey
BarracudaHockey's Avatar
I really love mine and a K45 is plenty so you're going to have a ball
Old 08-30-2018, 07:59 AM
BarracudaHockey
A few pics of mine....
Old 08-30-2018, 10:17 AM
LA jetguy
LA jetguy's Avatar
I will maiden mine tomorrow .. The M70 runs perfect... Danny and the team did an awesome job...
Old 08-30-2018, 11:36 AM
ltc
Is the consensus still to use the stock retracts.struts for paved runways, but use the Electrons ER30 for grass field use?
Are the stock units from JP?
It seems like a great airframe value for $629…
Old 08-30-2018, 11:39 AM
BarracudaHockey
The "stock" retracts are HSD and I would upgrade them, or at least the nose strut, for regular ops off of grass.
Old 08-31-2018, 09:38 PM
LA jetguy
LA jetguy's Avatar
Today I maiden the mini viper. Had seven flights on it. What an amazing little jet. The CG was set at 115mm.. it needed a few clicks of up elevator in all flight modes and a couple of clicks right aileron… and this jet was flying at 199++ mph on M70.
The take off speed was so high the electron gears could not retract fully. I had to lower travel rate of throttle for “Take-off” mode to 60% (almost 45N turbine power) for the retracts to complete cycle.
Once in “cruise mode” this little jet was ballistic. Landing was very gentle. I had flaps at 50mm and 3-4 mm crow…
Danny and the team at “Rocket Factory” did an awesome job of assembling
David
Old 09-01-2018, 02:37 PM
why_fly_high
My Feedback: (19)
What was the flight time? The tanks seems a little small for a 70.
Old 09-01-2018, 06:11 PM
LA jetguy
LA jetguy's Avatar
I get like 4-4:30 min ..based on throttle management.. land with 25% fuel in tank. I have not measured the capacity but I it seems to be around 1.0L (maybe less). In my experience "M" engines are more efficient than "K" engines...
PS... a wing tank will help flight time..
David
Old 09-01-2018, 07:25 PM
jesse2357
Danny Why not bus into the cortex pro?
Old 09-02-2018, 12:42 AM
F1 Rocket
This one is setup EX Bus from the REX 12 to the Cortex Pro with PWM out. In this mode the flight control surfaces and nose wheel steering are connected direct to the Cortex Pro. In affect the Cortex Pro is acting as a channel expander. With the REX 12 it is possible to get 19 channels. Just another cool feature of the Jeti/Cortex Pro combo
Old 09-02-2018, 01:07 AM
LA jetguy
LA jetguy's Avatar
Smile
It works very well... seamless on the transmitter and servo adjustment
Old 09-02-2018, 06:05 AM
jesse2357
Ok gotcha, it looks like it pwm in and out time it’s all those wires .
Old 09-02-2018, 07:13 AM
F1 Rocket
Actually just two wires between the REX 12 and Cortex Pro. One for EX Bus and the other for addition Power. The rest are all servo extensions. It’s a tight space to work in but this makes it fun to get everything organized so it fits and is easy to service.
Old 09-02-2018, 07:42 PM
Bob_B
Bob_B's Avatar
Using the same rx/gyro setup in my Viper Jet. Works great!
Old 09-07-2018, 04:46 AM
Toxic Al
What ended up being your final weight before fuel? I am at 9.88 lbs but it is tail heavy. I am using a swiwin 60. almost finished can't wait to get in the air.
Old 09-07-2018, 08:58 AM
F1 Rocket
The one I built is 10.25 lbs dry and needed approx 4 oz nose weight with the CG at 115mm from the leading edge of the wing where it joins the fus.
Danny
Old 09-07-2018, 11:24 AM
LA jetguy
LA jetguy's Avatar
Danny
And it flies great with M70... so happy with this jet
Old 09-07-2018, 03:20 PM
Toxic Al
Thanks Danny, at least I am not way off. I will be in the air soooon!
Old 09-26-2018, 06:07 AM
DepecheMode101
@LAjetguy when you can, Can you post pics of the landing gear install? The electrons are not bolt in.
cheers
Old 09-26-2018, 06:15 AM
Bob_B
Bob_B's Avatar
Neither gear is really bolt in but the mounts have to be backed up and extended slightly inward for the Electrons.
Mine has the HSD Gear. They work fine but def. not Electron Quality, mine is a 12S EDF setup.
Old 09-30-2018, 10:43 AM
DepecheMode101
Do you have use port 4 on the Cortex for additional power?
Old 09-30-2018, 12:05 PM
F1 Rocket
In this installation the additional power is connected to port A of the Cortex Pro.
Old 09-30-2018, 12:18 PM
DepecheMode101
thank you
