Great planes Seawind
Great planes Seawind NIB
Attachment 2262579
A beauty to behold -- in the air and on the water!
No other R/C seaplane looks or flies like the sleek and stylish Seawind! This sport-scale replica of the classic homebuilt amphibious aircraft will draw envious looks from fellow modelers, whether you're at the flying field or the local lake. And by substituting optional retracts for the included fixed landing gear, you'll have total access to land AND water with the same plane!- Constructed with the finest materials -- quality wood, gel-coated fiberglass and Top Flite®MonoKote® covering.
- Shaped like a speedboat's hull, the fuselage maintains straight tracking while enabling the Seawind to accelerate quickly onto the step for takeoff.
- A self-draining auto bailer is located on the bottom of the fuse, assuring that no water pools in the radio compartment.
- A foam stand is included for holding the model securely during assembly and starting; it also keeps the water rudder up off of the ground
