Go Back  RCU Forums > RC Airplanes > Aerodynamics
Air foils for Avro Vulcan delta wing 48"
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 03-19-2019, 05:19 PM
cyclops2
cyclops2's Avatar
Default Air foils for Avro Vulcan delta wing 48"
Scale appearance is a 3" thick root next to the body. HUGE leading edge air inlets to the engines...….. It is to be a sport plane. Stability when inverted would be nice. I will fly it as a bomber. Can I use a symmetrical airfoil for the main portion of the wing ? & a more stall resistant washout airfoil on the outer 3" of the wing for better stall resistance ? Like a Clark Y if I can find the pattern.
4 S F of wing area. The 2 wing panels are 8 oz. body will be about 3 oz. single tail pusher prop.
I do not mind having to use more power for the thick wing section. Please see if the scale wing shapes below are O K. Do I need any of the reflex curvature ?
Thank you.
Old 04-02-2019, 11:09 PM
BMatthews
BMatthews's Avatar
Cyclops, since the Vulcan is basically a flying wing you'll both want and need to use a wing airfoil with some reflex rather than a flat bottom wing with a strong camber value. That wing airfoil will act like you're holding a lot of down elevator in it.
I'd suggest you go for the pretty much scale symmetrical airfoil with some washout and reflex at the tip airfoils. In fact for a change even with a 48" span the chord will be so large that even at moderate flying speeds the Reynolds numbers will be so high that you will get away with the super thick root airfoil even with the funky inlet leading edge.
Old 05-30-2019, 02:21 PM
invertmast
My Feedback: (23)
invertmast's Avatar
This will save you alot of time and head scratching.
Tony Nijhuis Designs featuring 49 inch Avro Vulcan plan for Electric Power
Old 06-27-2024, 02:54 AM
eveningonly
Tailless delta wing aircraft require an S airfoil.
Old 06-27-2024, 07:55 AM
mgnostic
mgnostic's Avatar
If you are wanting the excercise of doing your own design there are a lot of delta wings to study over on Outerzone. Laddie Mikulasko designs in particular fly well. There are even a couple of Vulcans that you could refer to.
